2008 Kawasaki KLX 110 $1100 or best***SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2009, 07:34 PM   #1
pso728
pso728's Avatar
Default 2008 Kawasaki KLX 110 $1100 or best***SOLD***
This 2008 Kawasaki 110 4 stroke dirt bike was purchased for my son in 2008. The bike bike has a 3 speed auto clutch and a throttle limiter is included if so needed. It has less than 5 hours on it just ridden in the yard. He lost interest in the bike for riding and it was replaced by a quad. This bike is virtually brand new! Email for more photos or with questions. The bike was purchased for $1800 when it was new last year. Specs below are from the Kawasaki site;
# Engine: Four-stroke, SOHC, two-valve single
# Displacement: 111cc
# Bore x stroke: 53.0 x 50.6mm
# Compression ratio: 9.5:1
# Cooling: Air
# Carburetion: Keihin PB18
# Ignition: CDI
# Transmission: Three-speed with automatic clutch
# Final drive: Chain
# Frame: Backbone frame, high-tensile steel
# Rake / trail: 25.5 degrees / 2.1 in.
# Front suspension / wheel travel: 30mm hydraulic telescopic fork / 4.3 in.
# Rear suspension / wheel travel: Swingarm with single hydraulic shock / 4.2 in.
# Front tire: 2.50x14
# Rear tire: 3.00x12
# Front brake / rear brake: Mechanical Drum / Mechanical drum
# Overall length: 61.2 in.
# Overall width: 26.0 in.
# Overall height: 37.6
# Ground clearance: 7.5 in.
# Seat height: 25.6 in.
# Dry weight: 141.1 lbs.
# Wheelbase: 41.9 in.
# Fuel capacity: 1.0 gal.
pso728 is offline
Page generated in 0.18512 seconds with 27 queries
