weird car problem - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2009, 01:47 PM   #21
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Originally Posted by PavementPounder View Post
Why do people ask Tech Questions in the Pub?
Because I wanted a faster answer.
Old March 16th, 2009, 01:48 PM   #22
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Originally Posted by hosejockey4506 View Post
why do people ask questions and then when they get a answer they dont want they want to argue with you
who's arguing?
Old March 16th, 2009, 01:50 PM   #23
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Originally Posted by pokerob View Post
plastic or metal?
if plastic use something like PC-7 (sort of like JB weld but million times better) and if its metal have it brazed.
*that is if you can find the spot where its leaking.
good luck.
thank you.
Old March 16th, 2009, 01:51 PM   #24
Pokerob
hug life
Pokerob's Avatar
Originally Posted by mikesova View Post
thank you.
yourrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
welcom
Old March 16th, 2009, 01:52 PM   #25
PavementPounder
PavementPounder's Avatar
Well, you got plenty of those. I guess you got what you wanted. Good thing some possible correct ones may be mixed in there somewhere.
Old March 16th, 2009, 01:56 PM   #26
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
Originally Posted by Disturban View Post
Dude nothing is going to cause a Radiator to leak but a crack or hole in the Radiator it's self. Just because you added coolent does not mean thats what caused it, it was just time to start leaking is all. As far as just leaking when it is cold well when things get hot they expand and maybe it expands enough to seal? Either way if you know for sure your leak is coming from the radiator just do yourself a huge solid and buy yourself a new one and call it a day...I guarantee if you put a new one in it wont leak and there is no bypass valves or any other crap that will cause your new one to leak.
or coolant can come out an overflow. I was just trying to make sure this didn't have some kind of funky overflow system that came out the side of the radiator. I wouldn't think so, because where it's dripping from makes the coolant go on other stuff. thanks for all the help. I will probably try to patch it from the top, since it's a pain to take the radiator out. if not, I'll replace it. thanks.
Old March 16th, 2009, 06:53 PM   #27
Yota Bill
ok fine. I was expecting that if it was just a normal crack, it would be more of a problem when it is hotter, because the coolant is under more pressure and would want to leak out more. It makes sense I suppose that the radiator is expanding and sealing it. I just wanted to make sure there wasn't some other factor playing a part in this. I'm not refusing to buy a new radiator, I just wanted to be sure that this was the only problem.
with a crack, the system is then vented, so no pressure...it quit leaking because the level dropped below the leak...if it were expanding from higher temps, the crack would open more, not seal (generaly)
Page generated in 0.27109 seconds with 44 queries
