1994 F250 E4OD swap to C6? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2009, 06:20 PM   #1
malibuman82wgn
Default 1994 F250 E4OD swap to C6?
Can i swap a E4OD trans in a 94 f250 351 4wd to a c6 and eliminate OD by just BOLT in or what modifications are necissary? thanks
malibuman82wgn is offline   Reply With Quote
Old March 15th, 2009, 09:32 PM   #2
jontboudrie
jontboudrie's Avatar
Default c6
should bolt up check flywheel -transmount- driveshaft length.speedometer runs off the rear end.so you should be good there.have to run vacum line so it will shift.
jontboudrie is offline   Reply With Quote
Old March 21st, 2009, 10:49 AM   #3
Broncoholic
Guest
Posts: n/a
Is the old trans any good? How much?
Old March 22nd, 2009, 12:19 AM   #4
malibuman82wgn
please delete...thanks guys
Page generated in 0.22102 seconds with 35 queries
