Ford Escape Plug-In Hybird Experience - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2009, 10:18 AM   #1
DuffMan
Your Message Here
DuffMan's Avatar
Default Ford Escape Plug-In Hybird Experience
Spent some time last week with a prototype Ford Escape Plug-In Hybrid.
Battery life was a little disappointing, with a 20-ish mile commute eating about half of the battery power - and that was using "gas engine mode" above 15 mph (most of the trip).
As batteries get better I could see this as a real option for many uses.
I hope they have really well-built starters - because it gets a workout shifting between modes. Performance was great for commuter/DD service.
The display (what mode vehicle was in, etc...) was really well done and integrated into the Sync/GPS system. The Escape was top-of-the-line trim-wise, which made it very comfortable. Got "thumbs up" from Prius drivers (hard to miss huge 6" "HYBRID" and "PLUG-IN HYBRID" graphics on vehicle.
Old March 15th, 2009, 10:24 AM   #2
xjmichigan
xjmichigan's Avatar
So, I assume that the starter cycling takes a lot of run time from the batteries?
Would it be more efficient to have the engine idle and charge for heavy city driving?
Old March 15th, 2009, 10:43 AM   #3
No, its not a normal starter, or, at least on something thats running ful electric mode, it *shouldn't* be. There isn't a starter, just a full electric drivetrain you just clutch in the engine and it starts.
Shutting off the engine during all that idle time is a big saver in city traffic.
Old March 15th, 2009, 10:54 AM   #4
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
So how do you swing a ride in something like that?
blizazer is offline   Reply With Quote
Old March 15th, 2009, 11:35 AM   #5
Disturban
Disturban's Avatar
All those problems have been solved...it's called a Chevy Volt
Old March 15th, 2009, 11:41 AM   #6
DuffMan
Your Message Here
DuffMan's Avatar
Management at a regional energy company that owns utilities.
When the batteries fall below a certain level, it starts the engine. It appears that if the climate control system calls for heat, it starts the engine to provide hot water (it did several times while parked and unattended, but "on").
Later in the day we did a lot of stopping/short trips/low speed work, and it attempted to stay electric all the time. It does use the "flywheeling" of the vehicle to charge the battery when stopping. Starting it is a lot like a diesel - turn it "on" to boot the computer and then move the starter to "start" to go. No noise.
As I said, the nice video display provided a very clear picture of current flows (battery to electric motor, gas engine to battery, etc...) and modes. Well done, whoever did that piece of work. Instrument panel had electric displays (charge+/charge-, battery level coaxial with gas level) well-integrated - again well-done and definitely market-ready (perhaps it's what is already used on the Escape Hybrids on the road today).
It used the started a fair amount - although I couldn't tell if it used kinetic energy to start the gas engine underway or just the starter. It was pretty quiet, so you couldn't tell - you just heard/felt the gas engine start.
Old March 15th, 2009, 11:53 AM   #7
Nuggets
I fix stuff!
Nuggets's Avatar
I look forward to when these new hybrids get old enough to come to me for repair. I think I will like working on them just because they are different.
Old March 15th, 2009, 01:03 PM   #8
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
my mother in law has a ford dealership, and she said it was unbelieveable how much specialized equipment tey had to get to work on the hybrids. including some non-conductive 20 foot pole to pull someone off in the event of their electrocution
jeepman784 is offline   Reply With Quote
Old March 15th, 2009, 01:42 PM   #9
shaker
In the band!
It really sucks how little info is available for those of us that are going to have to scrape these things off the street when they get smashed. And who knows what kinda added dangers may result from an accident.
shaker is offline   Reply With Quote
Old March 15th, 2009, 01:45 PM   #10
If the instrument panel has two color displays, with a speedometer in the center, thats from the Fusion:
Thats what I do for a living, designing those. I just finished the camaro and color displays in the LaCrosse. We're doing the Volt now. Funny how much exceitement is generated by a well done cluster. That cluster in the fusion is one of the most expensive I've seen, with two displays and low volume. Around $400 piece cost, compared to about $150 for a normal one with a single display.
Old March 15th, 2009, 02:00 PM   #11
DuffMan
Your Message Here
DuffMan's Avatar
Nice, but that's not it.
All electromechanical analog instrument panel with everything else running off the central video for the nav system on top of the center stack. For production, they might go with something more like the Fusion, since it wouldn't require the package to include the nav system/touchscreen.
Old March 15th, 2009, 04:24 PM   #12
Actually, we quoted it at work, so I could go look it up, if I felt like it. I work on the GM team, so don't usually look at the Ford quotes all that detailed.
For another OEM, we're working on a quote for an 8" center display, touch sensitive, proximity sensing, haptic feedback, etc.
Old March 15th, 2009, 05:45 PM   #13
kickstand
circling the drain
kickstand's Avatar
I rode in a saturn hybrid the other day with a friend who works at GM and had to put some miles on the car. I was rather impressed with the peppy-ness and the seamless transition to running on electric, gas, or a mix. Hybrid's are getting there....
Page generated in 0.26119 seconds with 61 queries
