1996 ZJ/2.5" OME/MX6/197k/Loaded - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2009, 03:18 PM   #1
_Kyle_
_Kyle_'s Avatar
Send a message via AIM to _Kyle_
Default 1996 ZJ/2.5" OME/MX6/197k/Loaded
I've owned this since October 2006 and known the kid who had it the year before that. I've done pretty much all the work to it. I'm asking $3500 but i'm open to offers. This Jeep is very reliable and has never left me stranded in the past 3+ years. Will also consider trades + cash from me towards a newer grand cherokee, trucks, etc.
Features:
4.0 Engine
4x4 - 242 transfer Case
Leather
Power EVERYTHING
Auto-dim Rear Mirror
Sun/Moon Roof
Power Driver/Passenger Seats
Auto Headlights
30" General Grabber AT2 All Terrain Tires
ProComp MX6 Adjustable Shocks
2.5" Old-Man EMU Spring Kit
Pretty clean paint and body - some rust starting under a couple of the doors and the rear lift gate. Interior has normal wear.
- Has pretty much every thing the Limited did minus the 5.2 and heated seats.
MANY replaced parts:
Oil changed every 3k with Valvoline High Mileage Blend & Tires Rotated every few months.
New Cat/Muffler - Early 07 (have the receipt still)
New Front Hubs/U-Joints - Fall 07
New Exhaust Manifold - Winter 08 (Stock one on the 4.0 cracked, common failure).
Shocks/Springs/Tires - March 08 (Less than 10k on them no - Have bills from the parts I ordered as well)
New Rotors/Pads - March 08
Professional Alignment - March 08
New door pins in the front - April 08
New Fluid in Front & Rear Diff/Transfer Case - Spring 08 (have receipt too)
New Battery - Summer 08
Aux Lighting - Summer 08
Gatorback V-Belt - Summer 08
Front Passenger Brake Caliper Replaced/Brake Fluid Drained and Replaced - Fall 08
New plugs and wires (cap/rotor replaced 2 years prior) - Nov 08
New Water Pump/Thermostat/Cooling System Flush - Dec 08
New Key FOB - Jan 09
There are probably a few more things, but I can't think of them at the moment.
Now the Bad: There are a few small cracks in the drivers side door panel arm rest where the previous owner pushed their elbow into. I'm also missing the fuse cover for the engine bay - I've never actually had it, along with one of the rear head rests. The rear tail light is broken (lens only, and the krylon on the rear corner is scratched off from an idiot at my work). The steering wheel also has wear on the top and needs recovered or replaced. The sunroof seal also needs replaced, or lived with. Everything else works in good order, it just needs a good cleaning since i've been too busy to do so.
Factory Build Sheet:
*EL - Leather Trimmed Bucket Seats -AZ - Agate ADLP - Skid Plate Group AFFP - Luxury Group APAS - Monotone Paint ARNS - Laredo Decor Group AWL - Off Road Group BAUS - 117 Amp Alternator BCES - 600 Amp Maintenance Free Battery BRGS - Anti-Lock 4-Wheel-Disc Brakes CACS - Low Back Bucket Seats CFNS - Rear 60/40 Folding Seat CGWS - Next Generation Front Air Bags** CKDS - Floor Carpet CKNS - Cargo Compartment Carpet CKRS - Cargo Net CKTS - Cargo Tie Down Loops CLES - Front & Rear Floor Mats CSAS - Spare Tire Cover CSCS - Cargo Compartment Cover CSRS - Passenger Assist Handles CUFS - Full Length Floor Console CUNP - Overhead Console DGB - All 4-Speed Automatic Transmissions DGKS - 4-Spd. Automatic 42RE Transmission DHAS - Lock-Up Torque Converter DHPS - Selec-Trac Full Time 4WD System DMDS - 3.55 Axle Ratio DRJS - Dana M35/194MM Rear Axle EAAC - All Engines ERH - 4.0L Power Tech I-6 Engine GBBS - Tinted Windshield Glass GCBS - Front Door Tinted Glass GEGP - Deep Tint Sunscreen Glass GEP - Flipper Liftgate Glass GFAS - Rear Window Defroster GNCS - Sun Visors w/Illum Vanity Mirrors GNKP - Rear View Auto Dim Mirror GRMP - Left Power Heated Mirror GSMP - Right Power Heated Mirror GTMS - Power Heated Mirrors GVBC - All Vehicles W/Power Mirrors GXMS - Remote Keyless Entry HAAS - Air Conditioning HGAS - Hood Insulation HGDS - Deluxe Insulation Group JAYS - Instrument Cluster w/Tach JCBS - 120 MPH Primary Speedometer JHAS - Var Intermittent Windshield Wipers JHBS - Rear Window Wiper/Washer JJAS - Cigar Lighter JJBS - Dual Note Electric Horns JKAS - Locking Glove Box JPAS - Power Windows JPBS - Power Locks JPWP - Power Lumbar Adjust KRSS - STRIPE/BADGE/MOLDING/COLOR KTSS - STRIPE/BADGE/MOLDING/COLOR KWSS - STRIPE/BADGE/MOLDING/COLOR K4AS - STRIPE/BADGE/MOLDING/COLOR K5AS - STRIPE/BADGE/MOLDING/COLOR LACS - Illuminated Entry LAGS - Warning Chime LAZP - Vehicle Information Center LBBS - Courtesy Lamps LBCS - Glove Box Lamp LBDS - Ash Tray Lamp LDAS - Underhood Lamp LDBS - Cargo Compartment Lamp LETP - Traveler/Mini Trip Computer LMGP - Automatic Headlamps LNJP - Fog Lamps LPSS - CHMSL Lamp LSAP - Security Alarm MDAP - Front License Plate Bracket MFZS - Bright Grille MHAS - Black Windshield Moldings MWGS - Roof Rack NAA - Federal Emissions NF5S - 23 Gallon Fuel Tank NHMS - Speed Control PR4 - Flame Red Clear Coat QR4S - Flame Red Clear Coat RAAC - All Radio Equipped Vehicles RAZ - AM/FM Cassette Compact Disc Radio RCGP - 6 Speakers RDDS - Fixed Long Mast Antenna SBAS - Power Rack and Pinion Steering SCVS - Leather Wrapped Steering Wheel SDAS - Normal Duty Suspension SUAS - Tilt Steering Column TBGS - Compact Spare Tire TBLS - Inside Mounted Spare Tire TRN - P225/75R15 OWL Wrangler AT Tires TZAS - Goodyear Brand Tires WJ6S - 15X7.0 Sport Aluminum Wheels WLZC - All Aluminum Wheels XEEP - Fuel Tank Skid Plate Shield XEFP - Transfer Case Skid Plate Shield XEUP - Front Suspension Skid Plate YAAS - Build To U S Market Specifications YGCA - 7 Additional Gallons of Gas ZFLP - Spring - Left Front ZJTP - Spring - Left Rear ZULP - Spring - Right Front ZXTP - Spring - Right Rear Z6AS - GVW/Payload Rating 1AAS - U.S. Dealer Retail 142S - Zone 42-Detroit 2TFA - Customer Preferred Package 2TF 26F - Customer Preferred Package 26F 3VSA - Customer Preferred Discount 636S - Ohio State Code 936S - Ohio State Coder
_Kyle_ is offline
Old March 15th, 2009, 10:39 AM   #2
_Kyle_
_Kyle_'s Avatar
Bump...
_Kyle_ is offline
Page generated in 0.19245 seconds with 29 queries
