Mounting roll cage to frame - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 13th, 2009, 03:54 PM   #1
Evilmudder
Evilmudder's Avatar
Default Mounting roll cage to frame
I am wanting to see pics of how attached their roll cage to the frame. Getting ready to do mine and would like some ideas on how to tie it into the frame.
Thanks,
Ben
Evilmudder is offline   Reply With Quote
Old March 13th, 2009, 08:40 PM   #2
Do you want to rigid mount it, or have it mounted with bushings?
Old March 13th, 2009, 09:02 PM   #3
Evilmudder
Evilmudder's Avatar
whichever way would be better. The jeep will get drove on the road some and also be wheelin rig. Is one way better than the other?
Old March 13th, 2009, 09:39 PM   #4
Well, if your tub is mounted with rubber body mounts still, then mounting the cage on rubber mounts would also be a decent idea. Otherwise, you have opposing forces at work and can damage the body.
You can do it cheaper than buying this kit, but the setup in Poly Pro's kit is a nice style and easy enough to fabricate.
http://www.polyperformance.com/showimages.php?id=433
But, myself, I would have put a diamond shaped plate on the frame where the tube is welded. And, I would try to have the frame tie-in tubes angle up from the frame to the cage foot as steeply as possibe, and only have a bend if necessary (as opposed to, say, coming out straight and then having a bend up to the cage foot).
Page generated in 0.25091 seconds with 35 queries
