stalling out - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 28th, 2006, 08:48 PM   #1
vwBOY
it's how i roll
vwBOY's Avatar
Default stalling out
i have a 1994 f-150 and it has 5.0 in it and i was driving it today and it stalled out 2 time the first time i was making a hard right going about 5-10 mph with foot on brake and then at lowes i was parked and put it into drive and started making hard left and did it again and i popped the hood and were the master cylinder bolts up to thebrake booster it looked like bake fluid was all ove it and spatered around the inner fender well but it drives fine ans stops fine need the help thanks a lot
adam
vwBOY is offline   Reply With Quote
Old May 28th, 2006, 08:53 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
adam
We would all love to help you but we cannot understand all that jibberish up there. Make what you saw more clear.
Old May 28th, 2006, 09:18 PM   #3
vwBOY
it's how i roll
vwBOY's Avatar
what do you meen
Old May 29th, 2006, 12:26 AM   #4
xjmichigan
xjmichigan's Avatar
ok from what i can understand your master c is leaking, internally or something, is the booster line filling with brake fluid and getting in to the intake of the engine?
hows the fluid level?
Old May 29th, 2006, 09:22 AM   #5
vwBOY
it's how i roll
vwBOY's Avatar
the level in the resivoir is full
Old May 29th, 2006, 09:37 AM   #6
boggin-machine
boggin-machine's Avatar
then im guessing if the resivor is full then it aint brake fluid leaking?
Old May 29th, 2006, 09:41 AM   #7
DeltaCavXJ
BCT made me hate Oreos!
Default power steering
well ford thats sounds like power steering but i dont know how that would make it stall cause mine leaks like crazy and most fords do and thats prolly not ur problem so look elsewere
DeltaCavXJ is offline   Reply With Quote
Old May 29th, 2006, 09:44 AM   #8
vwBOY
it's how i roll
vwBOY's Avatar
new power steering pump last winter and there isn't alot of brake fluid all over but it is there but not enough to make the resovoir go empty
Old May 29th, 2006, 09:48 AM   #9
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Can you please learn proper grammar?
If there is brake fluid behind the master cylinder it must be leaking from the back seal. Even if itís not enough to make the reservoir go empty, you should fix it before the seal blows. If the seal goes while driving, good luck stopping.
Old May 29th, 2006, 10:52 AM   #10
vwBOY
it's how i roll
vwBOY's Avatar
i had a ton of sand stone in it when it stalled out and it was leaking were the master cylinder bolts to the booster
Old May 29th, 2006, 11:05 AM   #11
deuce228
Redneck Poser
deuce228's Avatar
So replace the gasket. Then get a ton of rich black dirt, haul here to my house, and see if you stall anymore.
Old May 29th, 2006, 01:23 PM   #12
Toivo
Feel lucky?
Toivo's Avatar
Yes, now that I FINALY can comprehend wtf happened, like has been said, replace the master cylinder gasket, or you'll go to stop sometime soon, and have no brakes. Please take the three extra seconds out of your life next post and use proper grammar and English.
Old May 29th, 2006, 02:25 PM   #13
deuce228
Redneck Poser
deuce228's Avatar
Suggestion being to use MS Word and type what you want to post in there. Then you can simply cut and copy into here.
Good Luck
Old June 1st, 2006, 12:29 AM   #14
xjmichigan
xjmichigan's Avatar
you had a ton of stone in a half ton truck that your trying to sell?
Old June 1st, 2006, 08:01 PM   #15
vwBOY
it's how i roll
vwBOY's Avatar
acually 3/4 of a ton
Old June 15th, 2006, 10:55 AM   #16
SS
Bananarama!
SS's Avatar
This is the most ridiculous post I've seen in a while...
"I overloaded my F-150 with stone and gravel and it stalled it and started leaking something. What could it be?"
Stupidity. That's what it is. It's the guys like you that piss everyone off on the road when they grossly overload their truck and can't go faster than 40 mph. Just park the truck and drive your dune buggy.
-Jer
Old June 23rd, 2006, 11:30 AM   #17
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You win the 06/23/2006 daily E-Thug award. :miff:
@clarkstoncracker
Page generated in 0.31109 seconds with 74 queries
