1998 4x Dodge Dakota Front End Work - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 11th, 2009, 09:00 PM   #1
jakesjeep01
Fukc it
jakesjeep01's Avatar
Default 1998 4x Dodge Dakota Front End Work
It is shot in the front end. Front wheels are about to fall off. Steering is OK but 1 or 2 bad tie-ends.
I plan on rebuilding the entire front end on the truck while Im under there. Just wondering what I might bump into. I am looking for some pointers and insight from someone who has done this on same truck.
I know Im gonna have to get rivets out of top ball joints. Press in/out the bottoms. Not too sure what I am going to run into when I try to take control arm bolts out. Blue tip eraser?
My questions are:
1. Do you need a special tool to remove/install the control arm bushings?
2. Do I need a special tool to remove the inner tie-rod ends?
3. Besides:
A. Ball joints Top & bottom
B. Tie Rod ends- inner & outer
C. Control arm bushings
D. Sway bar bushings
E. Shocks
What else can I replace? I am trying to find replacement control arm bolts incase I hack them up, but cant find them on the net.
Any suggestions?
jakesjeep01 is offline   Reply With Quote
Old March 13th, 2009, 03:57 PM   #2
jakesjeep01
Fukc it
Thanks for all the help guys. Your awesome.
Old April 13th, 2009, 01:04 PM   #3
hotwired_1
I just worked on My 97 dakota
both Inner tir rod ends
both out tie rod ends
upper and lower ball joints
It was a royal Pain with out power tools
Tips from what I learned, get a good compressor with impact wrench, order all of your parts and double check that they are the right ones needed, and a bottle of tylenol.
I had to run to the part store several times because the part were not correct.
Good luck, follow the directions and have a back up plan
hotwired_1 is offline   Reply With Quote
Page generated in 0.25024 seconds with 32 queries
