SOLD PLS DELETE Sbc 408 Eagle Short Block - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2009, 07:12 PM   #1
1twisted1
1twisted1's Avatar
Default SOLD PLS DELETE Sbc 408 Eagle Short Block
1,500
motor has 50 miles on it but needs going though
This is a deal these parts new would cost you 2,675.73 plus the machining of the block.
Call shaun for more info 734-637-6290
Balanced Eagle ROTATING ASSEMBLY 408 with Damper,flywheel & Block
Comp Cams, Hydraulic Roller Tappet, Advertised Duration 270/276, Lift .495/.503
Cloyes Timing Components GEAR DRIVE
ARP Pro Series Cylinder Head Stud Kits
ARP Engine Bolt Kits
ARP Balancer Bolt Kits
ARP Main Bolt Kits
ARP Oil Pump Stud Kits
Edelbrock Victor Series Mechanical Water Pump
Moroso Oil Pump and Pickup kit, High Volume / Standard pressure
Moroso 7qt Street/Strip Oil Pan
Moroso Oil Pump Driveshaft
Edelbrock Victor Series Valve Covers
Fel-Pro Performance Composite Valve Cover Gaskets
Timing Pointer, Billet Aluminum, Black Anodized
Adapter, Oil Filter, No Bypass, Aluminum, Black Anodized
Spark Plug Wires, 409 Pro Race, Spiro-Wound, 10.4mm, Black,
K&N X-Stream Air Flow Assembly
Power Master Starter High
1twisted1 is offline
Old March 10th, 2009, 07:13 PM   #2
h2recoverer94xj
h2recoverer94xj's Avatar
Default heads
what heads are on this engine
h2recoverer94xj is offline
Old March 10th, 2009, 07:17 PM   #3
1twisted1
1twisted1's Avatar
Non It"s A Short Block
Old March 10th, 2009, 07:28 PM   #4
h2recoverer94xj
Default sorry
didn't catch that sorry
Old March 10th, 2009, 10:37 PM   #5
355 ci wrangler
Chevy Power
355 ci wrangler's Avatar
Send a message via Yahoo to 355 ci wrangler
So why does the motor need going through at 50 miles just wondering ?
355 ci wrangler is offline
Old March 10th, 2009, 10:48 PM   #6
1twisted1
1twisted1's Avatar
Dropped a oil line .5 mile from the house! -10 oil line & a high volume pump = needs new bearings.
Old March 11th, 2009, 11:59 AM   #7
Mudpuppyracing
Mudpuppyracing's Avatar
What type of pistons? What type of rods? Compression Ratio?
Mudpuppyracing is offline
Old March 11th, 2009, 01:24 PM   #8
1twisted1
1twisted1's Avatar
The RODS/CRANK are eagle kit # B13008 bought it balanced with the Balancer & Fly wheel. Rods have ARP fasteners. Summit's Part # is B13008030 has all the info.
Pistons are KB +30 Dish
Compression Ratios head cc
58cc-9.6
62cc-9.3
64cc-9.1
76cc-8.3
Old March 19th, 2009, 01:35 AM   #9
1twisted1
1twisted1's Avatar
ttt
Old March 19th, 2009, 06:03 PM   #10
chrisdun112
got any pics??
chrisdun112 is offline
Page generated in 0.20276 seconds with 53 queries
