Dodge Ram Wont Start!?!? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2009, 02:17 PM   #21
wheelinblazer98
wheelinblazer98's Avatar
OBD II scanner.
wheelinblazer98 is offline   Reply With Quote
Old March 10th, 2009, 02:19 PM   #22
guest
Send a message via AIM to guest
Originally Posted by wheelinblazer98 View Post
OBD II scanner.
Yea but will it read anything if theres no check engine light?
And doesnt the car have to be running?
Also, how did you get one for 23 bucks lol
guest is offline   Reply With Quote
Old March 10th, 2009, 02:25 PM   #23
wheelinblazer98
with no check engine light, im not sure. but if it started for even a minute and stalled it probably through a code.
you simply plug the scanner in, turn the key to the on position (no start) and push the read button.
it was on clearance but there should be a fairly cheap one available. or even pack it back up and return it after you are done.
here is one on line for 30
http://www.autoditto.com/cheap-obd-ii-scanner.html
Old March 10th, 2009, 02:27 PM   #24
fordfrog
fordfrog's Avatar
Default dam dodge's
I have ram in this problem be for their is crank sensor on back of the motor or it is the pick up mod in the dis.
fordfrog is offline   Reply With Quote
Old March 10th, 2009, 02:28 PM   #25
shaker
In the band!
You probably tripped the silent alarm.
shaker is offline   Reply With Quote
Old March 10th, 2009, 02:29 PM   #26
Pokerob
hug life
Pokerob's Avatar
Hells yea, or just slip one into your pocket and not pay for it, then if you need it again later you have one
Old March 10th, 2009, 02:44 PM   #27
84Scrambler
Anti-theft system. Your sister doesn't want her truck stolen...
Old March 10th, 2009, 03:02 PM   #28
guest
grow up
Old March 10th, 2009, 03:06 PM   #29
guest
Alright im gonna rent a scanner from autozone and have it checked at 6:00. Ill get back here. I think it could be the crank sensor. Thats what I keep hearing. Or the camshaft posistion sensor.
Old March 10th, 2009, 03:19 PM   #30
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
clogged cat...kinda had the same problem...just dont steal anyone else's go buy one or gut your's
bigjay is offline   Reply With Quote
Old March 10th, 2009, 03:30 PM   #31
guest
I was also thinking that. But that wouldnt just go bad instantly it would over time. The truck was fine up until the last two days.
Old March 10th, 2009, 04:20 PM   #32
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Originally Posted by ٩(͡๏̯͡-̃)/ *tHieF* View Post
Im confused.
You could have fooled me
Old March 10th, 2009, 04:41 PM   #33
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
@clarkstoncracker
Old March 10th, 2009, 04:48 PM   #34
84Scrambler
grow up
That comment from you is just hilarious.
Old March 10th, 2009, 05:45 PM   #35
bigjay
bigjay's Avatar
why is that cat new?...mine never made any rattle noises or what ever noises u think should make before it goes bad...it just fell and twisted itself..goin down the highway doin 70 then no power would barley do 25 and the check engine light would flash...
Old March 10th, 2009, 06:02 PM   #36
guest
Hmm, well your right. Ill deffinitly check it and see.
Old March 10th, 2009, 10:12 PM   #37
guest
Sooo, these truck deffinitly SUCK to work on. I came to the idea that the coil started going bad and it fouled out the plugs and thats why when I put the new one on it didnt help so I am now in the process of changing the plugs and coil. But wow is Dodge dumb. They put these metal things around the plugs. Not sure why?? But it makes it near impossible to get the spark plugs out because the socket wont fit down there. Anyone have a tip they can give me to help out with this poor design? lol not to metion its ten times harder doing out in the road in the ran with no street lights and no lights but the cell phone light.lol. And limited tools
Old March 11th, 2009, 12:44 AM   #38
1989gmc
1989gmc's Avatar
the number one problem you have is that it is a dodge.... just throw it away and start over with a chevy... lol. i would have to agree with the others on here and say that its a good possibility that the cat is plugged i have seen this happen many times. you are also right about changing the spark plugs. if that doesnt help that try a fuel filter ive also seen them cause similar problems when they get real bad.
1989gmc is offline   Reply With Quote
Old March 11th, 2009, 07:07 AM   #39
noodles
give 'er sh*t ay?
noodles's Avatar
All trucks have problems. The metal sheilds around the plugs are to divert the heat away. the cat could be pluged. you can always drop the exhaust at the manifolds and see if it fires up then. that would tell you if the cat is pluged. the OBD2 should read codes even if the check engine light is not on. Every time the engine light comes on it should log the code and save it as inactive. One guy mentioned the crank sensor going out, this happened to me. If it gets oil on it it takes the power away from the crank sensor , and cam sensor. both of these are a fun to replace
Old March 11th, 2009, 07:28 AM   #40
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Flashing check engine light == misfire.
Misfire == catalytic converter damage.
@clarkstoncracker
Page generated in 0.43357 seconds with 83 queries
