Dodge Ram Wont Start!?!? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2009, 01:28 PM   #1
guest
Send a message via AIM to guest
Default Dodge Ram Wont Start!?!?
Ok, its a 1998 Dodge Ram 1500 ext. cab. short bed 4x4 w/ the 318 5.2
The truck was acting funyn like when you get to 3000 rpms it would sputter or wanna stall. The check engine light came on and when ever you would jump on it it the check engie light would blink. I didnt make it to autozone in time to test it with a scanner. But I started it late that night and the truck was running fine and no check engine lights were comeing up. But this is gonna sound stupid. I was moving out of my house all night. And at like four in the morning I jumped in the truck to warm up(no heat in old house) and fell asleep. I cant remember if I started the truck or not. But the next morning I woke up in the house and went out to the truck to find the igntion on and the parking lights. So I must of started the truck and it stalled or something. So I jump started the truck and it started but as soon as I would let off the gas it would stall right out. After about 15 minutes of restarting it it finnally would idle. This was yesterday morning. Then it ran fall almost all day. The truck was really muddy from my backyard and I parked next to this big puddle in a parking lot and had my buddy drive past me through the puddle to wash my truck off. And he did, then went I went to move my truck forward it was running like crap and the check engine light came on and and would hardly move. So I took the air cleaner off. It was dry. The truck would idle decent but wouldnt rev up it would just bogg down and stall when you gave it gas. So I figured the cap and rotor got wet. I changed them and the put a ne coil on it and it still runs like crap. Not it wont even start, idle, nothing. It will just crank and if you hold the throttle allt he way open the truck will try to start and will start for a like 1 second and then shut down. I have no check engine lights or anything else. And all my accessories work. Any one got any ideas??
guest is offline   Reply With Quote
Old March 10th, 2009, 01:32 PM   #2
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Coil
Old March 10th, 2009, 01:34 PM   #3
guest
Already replaced it and it didnt help. So I put the old one back on and toook the new one back.
Old March 10th, 2009, 01:36 PM   #4
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
Battery? not enough voltage to keep things runnin'? Jump it to see if it acts better with the additional "juice"?
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old March 10th, 2009, 01:40 PM   #5
guest
Tried that I even tried a new battery out of my other car.
Old March 10th, 2009, 01:40 PM   #6
Pokerob
hug life
Pokerob's Avatar
LOLOLOLOLOLOLOLOLOLOLOLOL
i totally do that when i change my oil...
I fill all the oil quarts back up then glue the caps on then take them back....
free OIL changes FTW!!!!
Old March 10th, 2009, 01:42 PM   #7
03hemisilver
fouled plugs from sitting idling for hours? plugged cat? Got gas in it after idling for hours last nite?
Old March 10th, 2009, 01:45 PM   #8
wheelinblazer98
wheelinblazer98's Avatar
sounds like a fuel clog of bad connection to the fuel pump. possibly a short in the fuse box when wet. the mosture in the air could have caused the issue in the morning. and then washing the truck might have gotten more water into it.
good place to start would be to run a scan. i picked up a scan tool on clearance at murrays for 23 bucks 2 weeks ago. WELL WORTH THE MONEY.
aslo try tuning the key to the on position and listen to see if the fuel pump pressurizes the system.
wheelinblazer98 is offline   Reply With Quote
Old March 10th, 2009, 01:47 PM   #9
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
fuel pump or fuel filter
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old March 10th, 2009, 01:47 PM   #10
guest
But why would it run fine all day and then all the sudden it just wont even start? I don't think a cat would be that bad But maybe im wrong.
Old March 10th, 2009, 01:50 PM   #11
guest
Well I tried pouring a little gas in the throttle body and it didnt help at all??
Old March 10th, 2009, 01:52 PM   #12
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Did you check for spark? Maybe someone put sugar in your gas tank.
Old March 10th, 2009, 01:56 PM   #13
deuce228
Redneck Poser
deuce228's Avatar
Karma
Old March 10th, 2009, 01:58 PM   #14
wheelinblazer98
if its shorting in the fuse box only when its wet, then i might run fine somtimes and then wont when the box is wet. worth a look. anyway.
id get a scan tool or borrow one from a friend if i were you. it saves a ton of guesswork.
Old March 10th, 2009, 01:59 PM   #15
Pokerob
hug life
Pokerob's Avatar
i totally took a dump on aj's chest last night.
Old March 10th, 2009, 02:04 PM   #16
cj7007
CJ7007
cj7007's Avatar
lolololololol!!!!!!
cj7007 is offline   Reply With Quote
Old March 10th, 2009, 02:11 PM   #17
XXXJ
Desert Rat
XXXJ's Avatar
BaitCar?
Old March 10th, 2009, 02:13 PM   #18
guest
I did check for spark at the coil wire but not the plug wires.
Old March 10th, 2009, 02:13 PM   #19
guest
P.s. this is my Sisters truck.
Old March 10th, 2009, 02:13 PM   #20
guest
Im confused. Like a obd or dmb scanner??
Page generated in 0.33072 seconds with 83 queries
