New Member: 85' F150 4WD with 300-6 and 4 speed, need trans. help!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2009, 03:54 AM   #1
ret_Marine2003
1985 Ford F-150 4WD 300-6
Default New Member: 85' F150 4WD with 300-6 and 4 speed, need trans. help!!
Good morning.
I recently purchased a 1985 Ford F-150 4WD with 4 speed manual trans.
I am having an issue where the shifter forks or shifter is locked up.
The truck is currently stuck in third gear.
I want to fix this problem right, but the truck is currently outside and facing a snow bank. I will have to roll it down the hill to get to a garage.
Where do I fill the manual transmission with gear oil?
How do I check the trans fluid?
Where do I get parts?
Thank you for any assistance.
You are appreciated.
Semper Fi,
ret_Marine2003
ret_Marine2003 is offline   Reply With Quote
Old March 11th, 2009, 10:36 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
pull the upper plug out of the side of the trans, stick your finger in, the fluid should be just at the bottom of the hole or slightly lower.
if low just squirt some gear oil in.
if you want to swap fluid, drain by removing the lower plug first.
I doubt this will solve the problem you are facing though.
Old March 11th, 2009, 03:48 PM   #3
ret_Marine2003
Thumbs up
Thanks for the drain plug and fill location.
It has been a long time since I have danced this dance.
My back is not what it once was, so it is difficult for me to lay down in the slush under the truck and remember what I was going to do before I put myself there.
Any advice on being stuck in third gear?
Old March 19th, 2009, 07:57 PM   #4
ret_Marine2003
Question
...any advice for a 1985 Ford F150 300-6 w/ four speed manual 4X4 that is locked into third gear?
I hope to have some time this weekend to repair it.
Old March 19th, 2009, 08:42 PM   #5
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
I would pull the shifter and the top cover off the trans and look down inside to see what is going on. and go from there
ATOMIC_BADBOY is offline   Reply With Quote
Old March 19th, 2009, 10:27 PM   #6
Yota Bill
IIRC, there is a nylon bushing on the end of the shifter that wears out, and then the shifter can slide past one of the shift forks, locking it in gear...pull the shifter off, use a large screwdriver to re-align the shift forks, replace bushing, reinstall shifter...
but its been quite a while since I played with that problem, I may be thinking of something else...
*edit....BTW, thank you for enlisting to protect our freedoms
Old March 20th, 2009, 12:58 PM   #7
bj house
bj house's Avatar
yeah x2 on the shifter linkages. Both of our 6-cyl E150's had those transmissions. I would always shoot some lube at the linkage or it would start to freeze up over time. You should be able to rotate the tabs at the trans with a small wrench or ratchet with no load on the trans. If they don't want to move then you are going to have to look inside or pull it out to diagnose further.
Old March 21st, 2009, 09:40 AM   #8
Broncoholic
Guest
Posts: n/a
I am not sure I have a 88 F150 2wd the little pins that hold the shifter centered go bad and need to get replaced, I ahve the same problem, mine is stuck in 2nd gear. @x Lg screwdriver
PS: Thanks for your service, Did you get to shoot a towlhead?
Old March 22nd, 2009, 11:44 PM   #9
ret_Marine2003
Wink
I had the pleasure of training towel heads and other folks who come from similar situations.
I try not to shoot them.
I want to train them to shoot their foreign and domestic enemies who try to use their common issues and religions to subjugate the free population.
I would like our country to be able to leave there someday.
I am optimistic.
We have been in Europe and Asia for more than 65 years now.
Old March 25th, 2009, 06:41 PM   #10
Broncoholic
Guest
Posts: n/a
Not in this lifetime
Page generated in 0.28582 seconds with 53 queries
