PLEASE DELETE coil buckets - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2009, 11:22 AM   #1
86scottsdalek10
86scottsdalek10's Avatar
Default PLEASE DELETE coil buckets
up for sale is a set of custom coil buckets to run a longer coil suspension instead of more expensive coilovers. first wecut of the stock shock mount and welded in a fat gusset, that way you can build your own shock hoops and run ANY size shock you want. they were made to be used on a 7s race truck so they were constructed with durability and reliability in mind. they have 4140 chromoly water jet cut plates used to make an inner sleeve and side gusset. the inner sleeve allows the coil spring 4" down travel while other custom coil buckets restrict 4" of travel. this means smoother cycling, reducing strain on parts and allowing more travel. no need for the cheap hooks. very strong, clean welds, fresh paint, bolt to stock location. these can also be used for other applications as well. asking $50
86scottsdalek10 is offline
Old March 10th, 2009, 10:25 PM   #2
86scottsdalek10
ttt
Old March 10th, 2009, 10:35 PM   #3
88mudder
In the band!
pics?
88mudder is offline
Old March 10th, 2009, 11:20 PM   #4
86scottsdalek10
send me your email and i can do it that way
Old March 11th, 2009, 12:20 AM   #5
Hubbler
Hubbler's Avatar
pm sent
Hubbler is offline
Old March 11th, 2009, 12:34 AM   #6
88mudder
In the band!
trailrider125@yahoo.com
88mudder is offline
Old March 11th, 2009, 03:58 PM   #7
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
what style coils can these be used with?
94rangeron35s is offline
Old March 11th, 2009, 09:35 PM   #8
86scottsdalek10
93-97 rangers
Old March 12th, 2009, 08:44 PM   #9
86scottsdalek10
can easily be adapted for different vehicles....all it does is bolt to the frame
Old March 13th, 2009, 07:52 AM   #10
bigden
94 YJ
bigden's Avatar
Please send pics to icden82@yahoo.com. I have some with the kit I got but I wonder if these would work better?
bigden is offline
Old March 13th, 2009, 04:38 PM   #11
86scottsdalek10
pics sent
Old March 14th, 2009, 09:30 AM   #12
86scottsdalek10
bump
Old March 15th, 2009, 09:57 PM   #13
86scottsdalek10
updated price.
Old March 16th, 2009, 06:16 PM   #14
86scottsdalek10
bump
Old March 17th, 2009, 05:59 PM   #15
86scottsdalek10
up
Old March 18th, 2009, 06:51 PM   #16
86scottsdalek10
bump
Old March 19th, 2009, 08:07 PM   #17
86scottsdalek10
and again
Old March 20th, 2009, 06:06 PM   #18
86scottsdalek10
bump
Old March 22nd, 2009, 02:54 PM   #19
RZG90
RZG90's Avatar
im trying to adapt bronco and f150 coils to my 85 chevy. would these be usable with bronco coils and a 6inch lift or not
RZG90 is offline
Old March 22nd, 2009, 10:35 PM   #20
86scottsdalek10
nice truck in the avatar and yes you could....autofab is a well known company that actually uses f 150 coils on ranger setups for extra lift and i was going to use my old bosses 66 bronco coils for my application before i wrecked the truck. the coils were 5" taller by the way...it was going to be cheaper for me to do that then to buy eibach 5.5" lift coils so yes this would work for you.
Page generated in 0.28492 seconds with 83 queries
