YJ spring conversion problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2005, 11:04 PM   #1
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Default YJ spring conversion problem
So I'm doing an SOA with YJ 1 1/2" rubicon express springs. I have a problem though. When switching to YJ springs, I am tring to put the rear spring on and I noticed that on the hanger (which holds the shackle) the metal sheath inside the bushing is too small for the bolt that comes on YJ shackles. If I use a CJ bolt that fits the bushing, there is play in the shackle. I was wondering if anybody has run across this and how to solve it. The only thing I can think of is too buy a new bushing that is the correct size.
Anyone have any thoughts? Thanks!
87'YJ is offline   Reply With Quote
Old November 21st, 2005, 04:26 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
I would buy or make new shakles. Not quite sure why the bolt sizes are different. Or just take out that bushing and sleeve and get the proper size you want in there.
Old November 22nd, 2005, 01:49 AM   #3
PavementPounder
PavementPounder's Avatar
Are you using a YJ shackle & bolt + CJ hanger and bushings?
Old November 22nd, 2005, 12:23 PM   #4
87'YJ
87'YJ's Avatar
Yes. I just bought some Urethane CJ bushings and I'm going to take out the metal sleeve.
Old November 22nd, 2005, 02:03 PM   #5
PavementPounder
I don't know what to say other than...
...incompatible parts won't work together.
Beyond that, keep in mind that you are going to use parts in a manner other than which they were designed to be used and they will not perform as thy should - even if you manage to "bang the square part in the round hole". Road stability is greatly affected by tolerances and slack in the shackle area. If you eliminate the sleeve inside the bushing, there will still be a small clearance between the YJ bolt and the CJ bushing. This will allow for excessive lateral movement of the spring and cause the axle to swing cross-car under the Jeep. Countering deathwobble in the front is one thing, but you don't want the ass of the truck behaving poorly also.
If you haven't mangled all the parts, consider selling them and buying what will work. All you need to do is use CJ shackles and bolts with your CJ bushings and hangars, because CJ rears are the same width as YJ springs.
Old November 22nd, 2005, 02:30 PM   #6
Bahahahaa. I think you answered your own post right away.
Buy the right parts and they'll fit.
There, was that so hard?
Old November 23rd, 2005, 09:51 AM   #7
87'YJ
87'YJ's Avatar
You're both kind of right and kind of wrong. First of all the CJ bushings without the sleeve still are a VERY tight fit with the shackle bolt. Eventually it might wear down a little, in which case, i will replace the $10 bushing.
Using CJ shackles in the back is not a bad idea, but then the CJ shackle bolt on the bottom where it attaches to the spring wouldn't be the right size. That is also larger. The spring attached directly to the frame in a YJ where as it has a spring hanger in the CJs.
Its getting all figured out....Thanks for the feedback guys!! It helps me think through these problems!
Page generated in 0.25044 seconds with 44 queries
