4.0 to a 3.0 swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2009, 08:26 PM   #1
ranger98
titties
ranger98's Avatar
Default 4.0 to a 3.0 swap
How much work is involved in swapping a 3.0 into a 4.0 ranger
ranger98 is offline   Reply With Quote
Old March 5th, 2009, 08:32 PM   #2
creepyjon
first off, why???????
Anyway, the 3.0, 3.8, and 4.0 are all in the same family so they should have the same trans. BUT the 3.0/3.8 series engines are well know for very defective head gaskets. The 4.0 isn't much better, but at least it has more displacment, and doesn't eat gaskets quite as fast.
If you wanted to swap in a more durable engine, a 2.9 would be a better swap. But I don't know what trans bolt pattern that one has. Even the 2.9 isn't all that great, ford is really lacking in any good small engine to be honest.
Screw it, put a 302 in it, and be done!!!
creepyjon is offline   Reply With Quote
Old March 5th, 2009, 08:42 PM   #3
4.0L = good motor (as long as its ohv and not SOHC)
3.0/3.8L same ball housing
2.9L/4.0L same bellhousing
Dumperdave has a 4x4 ranger with a 3.0L in it that was rolled so the body is trashed....but motor is still good. If attempting to do such a swap then you'll want a donor vehicle for all the misc shit
Old March 5th, 2009, 09:31 PM   #4
ranger98
titties
ranger98's Avatar
Im buying a 99 ranger with a 3.0 2 replace the blown 4.0 and toasted tranny in my truck so im tryin to find the fastest and easiest way to go out the swap
Old March 6th, 2009, 06:16 PM   #5
creepyjon
well, it will bolt up. They did use that engine in that chassis, so it's an easy swap. You will have to do all the standard motor swap stuff. New motor mounts, complete wiring harness, and ecm from the donor truck.
however I would do a oil pressure test, a compression test, and possibly a coolant pressure bleed down test on that engine before putting in. If you want to do it right, do the head gaskets while it's on the ground and easier to work on.
Old March 7th, 2009, 12:26 AM   #6
deathbypsi
Brian R.
deathbypsi's Avatar
Dear God stay away from a 3.slo
Hold out for a cheap 4.0
Old March 7th, 2009, 06:42 AM   #7
dumperdave
dumperdave's Avatar
I had good luck with the 3.0, as John said the 4.0 and 3.0 have different bell housings.
I didnt know that they still used a 3.0 in 99.
dumperdave is offline   Reply With Quote
Old March 9th, 2009, 05:42 PM   #8
ranger98
titties
ranger98's Avatar
Bump
Old March 9th, 2009, 05:44 PM   #9
ranger98
titties
ranger98's Avatar
alrighty man i appreciate the help
Page generated in 0.27184 seconds with 50 queries
