2001 F-150 Cruise Control - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2009, 04:57 AM   #1
bigblue2230
still goin
bigblue2230's Avatar
Default 2001 F-150 Cruise Control
The cruise control on my truck quit working, and when I push the SET button, the cruise light flashes once, and then nothing happens. has anyone runinto this before, or know what it might be? It's cold out still and the less time standing out there checking wires the better.
2001 F-150 crew cab.
5.4L 4x4
Auto trans.
bigblue2230 is offline   Reply With Quote
Old March 4th, 2009, 06:22 AM   #2
Medic8
You call, we haul.
Medic8's Avatar
First big thing... have someone tap the brake pedal while you watch the brake lights. If your brake pedal switch is non-functioning/ malfunctioning, it will affect the operation of your cruise control.
Is your MIL (Check Engine) light on? Or is your Overdrive Off light on constantly/ flashing? If so, you've got a Diagnostic Trouble Code (DTC) set somewhere that might be an indication of a problem. For example, VSS (Vehicle Speed Sensor), TPS (Throttle Position Sensor)... those could affect your cruise control operation as well.
I just looked on the Ford Service website and it says that according to your symptoms (Light flashes once after you press the SET button, no "dynamic pull" meaning your truck doesn't accellerate briefly then settle into speed, and no function of speed control) it's most likely the control cable or the servo motor.
It says to check the speed control cable for proper connection at both ends, then to check and make sure the cable isn't kinked or binding. If the cable operates freely and is connected properly, it's most likely the servo motor itself.
Old March 4th, 2009, 04:01 PM   #3
bigblue2230
still goin
Ok, no DTC's, brake lights work, and cable is connected and has no kinks/binds. Guess I will try finding a new motor or one someone can lend me to try. THanks
Old March 4th, 2009, 04:04 PM   #4
big burt
big burt's Avatar
Send a message via AIM to big burt
Have You Had The 05s28 Recall Done? Its A Speed Controul Modification That Was A Recall On Your Year. Try That. You Can Call It Into Any Ford Dealer.
big burt is offline   Reply With Quote
Old March 4th, 2009, 08:04 PM   #5
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
x2 on the recall. Mine still needs it.
Old March 4th, 2009, 08:05 PM   #6
HVYRTFT
Reed my teef
HVYRTFT's Avatar
X2 on the recall, hope it doesn't catch on fire!!!
Old March 21st, 2009, 10:27 PM   #7
ASEBlackFx4
ASEBlackFx4's Avatar
Another thing to add is if you use the tilt function regularly, the wires that run down the column like to break, seen that a couple times.
ASEBlackFx4 is offline   Reply With Quote
Page generated in 0.21552 seconds with 44 queries
