D60 Rear Disc Brake Bracket (Ford)! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old February 27th, 2009, 09:31 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow D60 Rear Disc Brake Bracket (Ford)!
Here you are, an easy bolt on bracket for the Ford D60 Rear axles! This one also uses the GM Caliper ('73-87 3/4 Ton 4x4 Front) because it is 1/2 the cost of the Ford and way less expensive to put together than the wedge system. The rotor is a '75 Chevy 3/4 4x4 Ton Front rotor. These were a long time coming but way worth the wait! These come with the required hardware. All of our brake brackets are sold in pairs.
These are only for the Ford D60, if someone tells you they are the same hang up the phone, they, the GM & the Dodge are all different!
AS always $50 a pair! And don't forget the discount!
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Thread Tools
Page generated in 0.24072 seconds with 26 queries
