F@#$ the 22RE! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2009, 07:00 PM   #1
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
Default F@#$ the 22RE!
I've done everything short of replacing the whole damn motor trying to track down why it runs like shit, and nothing worked. Ive done everything I've been told to do, and no changes at all.
Fucking [/rant.]
Its gonna sit and collect bird shit until I get a 4.3l/SM465/NP205 stuffed in it.
Old February 27th, 2009, 07:02 PM   #2
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Do you feel better now?
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old February 27th, 2009, 07:03 PM   #3
Rebel2345
Rebel2345's Avatar
Not entirely. I'll feel better when its out of the truck and I'm bashing it with a 10 pound sledge.
Old February 27th, 2009, 07:06 PM   #4
MusKegon_ZJ_gurl
I suggest a lighter sledge, maybe an 8# for a easier swing.
Old February 27th, 2009, 07:20 PM   #5
Rattler
Home Sweet Homicide
Rattler's Avatar
What is it doing?
Old February 27th, 2009, 07:21 PM   #6
mpwal099
Stick it up your ass
mpwal099's Avatar
Originally Posted by Rattler View Post
What is it doing?
Originally Posted by Rebel2345 View Post
it runs like shit
mpwal099 is offline   Reply With Quote
Old February 27th, 2009, 07:46 PM   #7
Rebel2345
Rebel2345's Avatar
Barely wants to idle after it idles down when warming up, misses, hesitates when I press the throttle to the point of almost stalling, runs rich. It backfires multiple times when downshifting to slow down. Gutless until about 2500 and then rips like a raped ape while spewing black smoke.
All started after I sucked water in the motor. I thought it skipped a tooth on the timing because it started running bad instantly after it happened. but I just replaced all that and nothing changed.
I've replaced the AFM, 02 sensor, checked the TPS sensor and it tested fine, went though all the vacuum lines, plugs, wires, cap, rotor... Went through all the stuff listed in the book.
Old February 27th, 2009, 07:50 PM   #8
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
sounds like you hurt the motor internally bent a rod or something
spr_chicken is offline   Reply With Quote
Old February 27th, 2009, 08:15 PM   #9
Rattler
Home Sweet Homicide
Rattler's Avatar
I was thinking timing chain.
Post up over at TTORA. Those guys can get cocky but some really know their stuff.
Old February 27th, 2009, 08:56 PM   #10
Rebel2345
Rebel2345's Avatar
Oops, thought I said that, but no, no bent rods and the compression is near spec, two are a little below but not enough to hurt it that much.
I'm not even going to bother anymore. Spent too much time and money on that turd already.
Old February 28th, 2009, 09:07 AM   #11
cruiserjg
dodge man
cruiserjg's Avatar
sounds like it has more fuel presure than it needs.
cruiserjg is offline   Reply With Quote
Old February 28th, 2009, 09:11 AM   #12
kickstand
circling the drain
kickstand's Avatar
Ignitor. My 22re did the same thing. I also fucking hate that motor.
Old February 28th, 2009, 09:13 AM   #13
Nuggets
I fix stuff!
Nuggets's Avatar
Send it to me and I'll get it running right.
Old February 28th, 2009, 11:24 AM   #14
Rebel2345
Rebel2345's Avatar
I'll give that a shot too.
I would but I'm afraid there will be a Pinto body on the frame when I get it back
Old February 28th, 2009, 03:27 PM   #15
Rebel2345
Rebel2345's Avatar
Been out playing with the timing and such today. I was planning on messing with the TPS sensor, and I just unplugged it for a second and it idled up pretty high. started messing with the timing again and for whatever reason it started running alright, still feels gutless under 3000 rpm but it didnt backfire when downshifting, its not missing nearly as much. I think I'll go out and mess with the TPS and see what I get.
Old February 28th, 2009, 03:39 PM   #16
Rattler
Home Sweet Homicide
Rattler's Avatar
Do you have a Chilton's or Hayne's manual?
Not sure there are factory service manuals online.
Old February 28th, 2009, 08:16 PM   #17
Rebel2345
Rebel2345's Avatar
Yeah I got a Haynes.
For a little while it didnt run rich at all, but then it started blowing a slight cloud again. Still running better than it did though.
Something odd happened with my tachometer though. (Its an old Suntune Digital tach) I was cruising down the road and suddenly it flipped out, the line that goes across the scale for RPM maxed out and then it just started flashing numbers really fast. Did it until I turned it off and then it was back to normal. Never done it before.
Old March 3rd, 2009, 10:42 PM   #18
TAZ03DAK
HA!
TAZ03DAK's Avatar
Have you checked for a crack or small leak in the intake? I just got mine running right after fighting with everything else, found a leak in the intake manifold. Runs great now, still very underpowered under 2500rpm, but i'm still trying to get used to dealing with a 4cyl.
TAZ03DAK is offline   Reply With Quote
Old March 3rd, 2009, 11:14 PM   #19
Rebel2345
Rebel2345's Avatar
Thats another thing I checked. Didnt find anything though.
I'm pretty much giving up on finding the problem. Its running half way decent right now, so I'm just gonna run it until I get my swap parts together.
Old March 3rd, 2009, 11:20 PM   #20
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Put a big block in it, doesn't matter which brand. Cool points.
Page generated in 0.34844 seconds with 83 queries
