Ford 4.0 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2009, 11:31 AM   #1
Jdc215
Jdc215's Avatar
Default Ford 4.0
im looking at buying a 94 ranger with a 4.0 motor and about 218,000 miles on it are there any common problems with the 4.0 i should know about concerning the motor.
Jdc215 is offline   Reply With Quote
Old February 25th, 2009, 01:00 PM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Some have been known to have head gasket issues. That's about all I know of. They're pretty solid engines.
Other issues:
Is it an auto or a manual? The Auto's have by far the wort issues in those things. Basically all of them are junk unfortunately.
If it has 4x4 the electric shift motor has some issues, but it just needs cleaned out regularly. There's instructions for that *here*
Other questions include if it is an extended cab? The carrier bearings have alot of issues. Well, not necessarily the bearing, the rubber isolator that is part of it rots and then takes out the bearing. Rather annoying, but also easy to fix *here*
Any other questions?
Old February 25th, 2009, 05:15 PM   #3
Jdc215
Jdc215's Avatar
its a manual and not extended cab, and he claims the shift motor is in good shape.
Old February 25th, 2009, 05:54 PM   #4
Captain Ledd
Ranger Addiction?
Well then you should be all set then
Old February 25th, 2009, 08:53 PM   #5
Jdc215
Jdc215's Avatar
thanks
Old February 25th, 2009, 09:09 PM   #6
creepyjon
x2 on head gasket issues, they have a habit of eating them.
Also the 4.0's suck at gas mileage, but it will have lots of torque for a little truck.
Check the rear cab mounts for rust, and check the rear spring hangers for rust. Both places are common problem areas on them trucks.
creepyjon is offline   Reply With Quote
Old February 25th, 2009, 09:22 PM   #7
the intakes leak coolant......and valve covers dump oil
Old February 27th, 2009, 01:09 AM   #8
88mudder
In the band!
they will tick just like a 2.9 after alot of miles
Old March 8th, 2009, 06:19 PM   #9
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
ive had 2 engines around 100-140000 miles spit out the timing belt tensioner, which you have to pull the engine, and tear it all apart to change. i guess this is a comon problem.
lososjoyride00 is offline   Reply With Quote
Old March 8th, 2009, 11:25 PM   #10
hillbillyrockstar
Country folks living LOUD
hillbillyrockstar's Avatar
Location: from St. Clair County, working in Baltimore MD for a while
Maybe yur intake leaked coolant. Out of the 3 4.0's I had, I never had an issue with that.
I did however have an issue with the headgaskets. They went bad on one out of the 3 4.0s I had. Other than that, I would be more than willing to put a stock 4.0 up against an I6 4.0 from a Jeep without a question. They have quite a bit of torque. But they like gas for a mid-size truck, their mileage sucks ass.
hillbillyrockstar is offline   Reply With Quote
Page generated in 0.25660 seconds with 53 queries
