can't get my 92 TBI 5.7L with painless kit to start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2005, 08:07 PM   #1
Bones
Bones's Avatar
Default can't get my 92 TBI 5.7L with painless kit to start
Don't tell me timing is off, it aint. Aaron (4bangler) and myself went therough the timing about 5 times. We even kicked it and it didn't start.
Motor- 92 TBI caprice 350, pretty clean under the valve covers.
I have the painless kit. No VSS hooked up, no brake switch, no trans control, no EGR hookup. The 2 park detect wires are connected
I have tried 2 different IACs and 2 TPS, all the same. 02 sensor is new. New plugs, wires and cap (not rotor). rockers are rockin and lifters looked fine.
fuel pump hits 10-12 PSI.
I think thats about it. This is what it does.
Sorry the you have to listen to the lions losing in the background.
https://home.comcast.net/~bill.bridge/CSVT/MVI_0573.avi
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 20th, 2005, 09:27 PM   #2
Bones
Bones's Avatar
I should mention all cylinders get spark (as per timing light on each wire)
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 20th, 2005, 11:26 PM   #3
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
i think that thos injectors need 13 psi, does it look like they are spraying good?
GMCsonoma94 is offline   Reply With Quote
Old November 21st, 2005, 05:03 AM   #4
Bones
Bones's Avatar
yeah, i think the injectors are OK... it does the same thing with starting fluid in the intake
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 21st, 2005, 07:36 AM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I am not replying to all the boards. Well ok I am I am chasing the sources. Since we do know that is does the same with added fuel source. Do the cheap method. Pull each plug squirt in some oil to get compression. I had to do this with the YJ.
Old November 21st, 2005, 12:59 PM   #6
Bones
Bones's Avatar
I've never done that... what does it do?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 21st, 2005, 11:21 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
Builds compression Quicker ...
Old November 22nd, 2005, 09:31 AM   #8
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
check your firing order :tonka:
Old November 22nd, 2005, 09:43 AM   #9
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
Pull the plugs and watch them spark against the block while you crank it.
blizazer is offline   Reply With Quote
Old November 23rd, 2005, 03:02 AM   #10
GMCsonoma94
1 wheel peel
you shure the timing isnt 180 off?
Old November 23rd, 2005, 05:15 AM   #11
Bones
Bones's Avatar
yeah, i think i got it though, i'll post p sat or sunday when i work on it again
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 28th, 2005, 12:01 AM   #12
Mclovin
"The Situation"
Mclovin's Avatar
Well did you get it ??
Old November 28th, 2005, 04:14 AM   #13
Bones
Bones's Avatar
yup, now i have codes 22 and 32. 32 is EGR, 22 is... I don't know...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 28th, 2005, 04:14 AM   #14
Bones
Bones's Avatar
i should mention I don't care about the codes
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 28th, 2005, 11:50 PM   #15
Mclovin
"The Situation"
Mclovin's Avatar
"Don't worry Reading's for Rich people" So dont bother readin them codes
Page generated in 0.38542 seconds with 68 queries
