Some updated pics of mine in the mud.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 24th, 2006, 10:51 PM   #1
Default Some updated pics of mine in the mud..
These were from our canada run. Sorry about the size, this is the size of my desktop at work, so I'm killing two birds with one stone..
This was in early may, north of the Soo..
As bad as some look, she never got stuck. Although the one pic where I'm so far down into the mud, it pushed the front clip on solid ground, so the radiator shroud bent into the fan.. (Taurus fan going in soon...)
Enjoy.
Tow rig setup (96 V10 dodge... doubles as my place to sleep :) )
Still clean:
Not anymore..
Old May 24th, 2006, 10:53 PM   #2
BTW, for this trip, I had replaced my old 22R with a 22RE, and swapped axles to an IFS rear, and 4.88 gears front/back (front lock-rite, rear spool).
The 100:1 gearing was awesome, and the truck worked excellent all weekend..
Old May 24th, 2006, 11:09 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
Looks like a kick ass time !!! Did you ever figure out some kind of rear fender to avoid the constant rear bathing ??
Old May 25th, 2006, 08:38 AM   #4
Not yet.
I just got my plasma cutter, which should make it easy to cut some diamond plate to fill in my fenders. I'm going to lower the gas tank a little, then put a shelf across the top of it, for a tool box, air tank, battery box, and water tank(plumbed to sprayers). Also build a better spare tire mount than my ratchet straps :tonka: . So at that point, I'll fill in everything with diamond plate.
Old May 27th, 2006, 10:32 PM   #5
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
r u stuck in last pic? that stuff looks deep and sloopy but a gr8 time.
hman1991 is offline   Reply With Quote
Old May 28th, 2006, 08:12 AM   #6
No, not stuck. It took a few runs backward to forward, but was able to pop out of that, and drive up and out.
Old May 28th, 2006, 11:53 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
Originally Posted by Haggar
Not yet.
Whats wrong with ratchet straps ??
Old May 30th, 2006, 08:44 PM   #8
General Lee
Slice of Starsage Anyone?
General Lee's Avatar
Send a message via AIM to General Lee
Sorry for the semi-off topic, but do you know what size tires that TJ was running???
Thanks!
Jim
General Lee is offline   Reply With Quote
Old May 31st, 2006, 10:30 AM   #9
Thanks!
Jim
Which one The dark one(TheChuckles) or the red one(big Daddy Rubicon)?
Chuck is running 35x12.5 Swamper SSRs, BDR is running 37" Irocks.
I'm in between with 36x12.5" SXs...
Old May 31st, 2006, 12:46 PM   #10
General Lee
I ment the dark one (I didn't even notice )
Bummer. I'm only going to 33s...
All of the vehicles look sweet, though!!!
Old May 31st, 2006, 12:51 PM   #11
BDR is hiding behind my truck in the trestle pic...
Old May 31st, 2006, 02:04 PM   #12
General Lee
Yeah, I found him after you mentioned his tire size.
Page generated in 1.25116 seconds with 59 queries
