87 F250 - What OD trans to swap in? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2009, 01:27 PM   #1
four_by_ken
Need a strap?
four_by_ken's Avatar
Default 87 F250 - What OD trans to swap in?
What over drive trans is the one to swap to in an '87 2wd F250, 2wd, 460ci?
E4OD?
Will it be a direct swap?
Other options that are low cost?
four_by_ken is offline   Reply With Quote
Old February 23rd, 2009, 05:16 PM   #2
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
i'm not sure but i bought a 89 f250 and it had a c6 wich is not an overdrive tranny. but for yours i would think it would be a AOD if you wanted one with overdrive, make sure the bellhousing is for a bigblock because there is a difference, E4OD is electronic so it would not work.
ATOMIC_BADBOY is offline   Reply With Quote
Page generated in 0.10820 seconds with 29 queries
