S10 Sas? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2009, 08:55 AM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default S10 Sas?
well i'm planning out my SAS on my 95 S-10. anyone here ever done one? what brackets did you use to make it all work. looking into this kit http://www.sky-manufacturing.com/new...uct.php?id=197 to do the front. any suggestions?
Old February 23rd, 2009, 09:06 AM   #2
roll-bar Bob
roll-bar Bob's Avatar
$200 for $50 worth of steel
if you have the know how to put that kit on, you have the know how to make the kit in your garage
Old February 23rd, 2009, 09:09 AM   #3
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Are you going fullsize or some narrowed axles??? I started my own SAS on a 91 s-10 and found that the Front Dana 44 out of a Jeep J-10 Pickup is almost the same width as the s-10 frame, frame over perch wise, and it's passenger side drop so you can use the factory case in the S-10.
Old February 23rd, 2009, 09:11 AM   #4
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Talk to Mclovin he wheels a SAS S10
ckupq is offline   Reply With Quote
Old February 23rd, 2009, 09:28 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i'll be using a dana 44 out of a 84 wagoneer. drivers drop so t-case will work. only reason i want that kit is cuz i'm a crummy fabricator. buying something i can simply bolt on then have someone else weld it together is better for me.
Old February 23rd, 2009, 09:32 AM   #6
88 TONKA TOY
Rockin an XJ
88 TONKA TOY's Avatar
Send a message via MSN to 88 TONKA TOY
contact knaffie on this board he has sas'ed a couple of s10's and could hook ya up with a front cross member to fit your needs. He is located in jackson
88 TONKA TOY is offline   Reply With Quote
Old February 23rd, 2009, 10:12 AM   #7
Medic8
You call, we haul.
Medic8's Avatar
ZR2 USA forum about Solid Front Axle conversion
Everything you would want to know about SFA/SAS on an S10.
Old February 25th, 2009, 12:16 AM   #8
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
http://www.greatlakes4x4.com/showthread.php?t=108383
Although, I didn't do leaves in the front obviously.
http://www.s10extremist.org/sfa_rigs.htm
http://www.s10forum.com/forum/f221/s...e-list-336841/
I think the only thing I have to say about doing the swap, don't cut too many corners. I still DD mine, but I really wish I would have shelled out some more cash for other stuff.
I don't know if 95's had it or not, but my 97 had the CV style front output and I am swapping it out for the cardan style from an older 231. That CV was toast pretty quickly.
Grunto is offline   Reply With Quote
Page generated in 0.20412 seconds with 47 queries
