spark knock when towing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2009, 07:56 PM   #1
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
Default spark knock when towing
i have a 96 f150 351w efi and whenever i tow something it starts to spark knock, i tried octane booster and it didn't make a dfference.
ATOMIC_BADBOY is offline   Reply With Quote
Old February 22nd, 2009, 08:00 PM   #2
Freak
Wheelin the HD
Freak's Avatar
Timing?
Old February 23rd, 2009, 08:15 AM   #3
deathbypsi
Brian R.
deathbypsi's Avatar
Look for cracked or missing vaccum lines. If there is a small line off or a vac leak the ECM can still correct the air/fuel ratio under normal conditions but when you add a load it will be too lean to make the power it needs to pull and will rattle. Last three trucks I have had had this happen at some point.
Old February 23rd, 2009, 08:18 AM   #4
ATOMIC_BADBOY
Shake n Bake
i keep getting a engine code the its running lean
Old February 23rd, 2009, 08:34 AM   #5
deathbypsi
Brian R.
deathbypsi's Avatar
Then you need to find your vaccum leak. If I am wrong I will buy you a pop.
Old February 23rd, 2009, 11:38 AM   #6
ATOMIC_BADBOY
Shake n Bake
ok thanks man
Old March 2nd, 2009, 02:16 PM   #7
Broncoholic
Guest
Posts: n/a
I have a 351w performer with a holly 650 should cure it.
Better do somthin quick my last efi leans out the rear pistons
and then you will have a 7 cyl.
Page generated in 0.24033 seconds with 44 queries
