project (renamed) Old Iron cj2a - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2010, 10:26 PM   #141
stinkpickle
bitter clinger
stinkpickle's Avatar
Took it out for a drive today. getting a lot of rust in my fuel filter and clogging it. Probably just gonna pick up a new one. Carb has developed a leak after sitting awhile gotta get that fixed. lots to do still.
stinkpickle is offline   Reply With Quote
Old September 21st, 2010, 10:27 PM   #142
stinkpickle
bitter clinger
Originally Posted by ckupq View Post
So when does the rest of the drive shaft get there? Was it too expensive to ship with the extra tube added to it?
thats it, all 12 inches of it! shipping was free just had to wait a week.
Old September 25th, 2010, 09:53 PM   #143
stinkpickle
bitter clinger
Worked on the jeep today. put new gaskets in my leaky carb (thanks Brian for the advice) and swapped out the old, rusty, leaky gas tank for a new one. its nice to see clear instead of red fuel going to the carb.
out with the old...
[IMG][/IMG]
in with the new and rust problem solved.
[IMG][/IMG]
The stock fuel tank has a capacity of 11 gallons, not gonna last too long feeding a sbc. So Im thinking of adding another tank to supplement my fuel needs. Picked up a plastic jerry can from the local military surplus store I plan to run a fuel line with cut-off valve from the jerry can to the fuel tank.
[IMG][/IMG]
Had to solder in some brass fittings for the fuel line and breather hose.
[IMG][/IMG]
Possible mount location for jerry can.
[IMG][/IMG]
Old October 20th, 2010, 07:39 PM   #144
SageJp
SageJp's Avatar
Is your steering hooked up? I've been thinking about swapping a 4.3 in a cj2, but not sure what other flatty builders do about steering box location.
SageJp is offline   Reply With Quote
Old October 21st, 2010, 07:06 AM   #145
stinkpickle
bitter clinger
Steering is hooked up. Currently Im using the origional ross set up. so no steering mods yet. I do plan to go to the power saginaw set up. check out Early cj5, lots of flatties on that site.
Old October 21st, 2010, 04:05 PM   #146
stinkpickle
bitter clinger
Been working on the project steadily. Mostly electrical stuff, hooked up new LED taillights, head lights and running. Still working on turn signal, found an old rotted cj5 out out behind our property up north, scavenged and cleaned up the turn signal I ripped off it. gotta figure out how this thing hooks up to the new harness.
Old October 28th, 2010, 08:10 PM   #147
deathbypsi
Brian R.
deathbypsi's Avatar
I will have your carb finished tomorrow Shane. Worst carb I have seen yet. The rust pored out of it!
This was a clean pan when I started.All of this just fell out of the bowls.
Gonna switch it over to a quick change secondary diaphram since this one is trashed.
Old October 28th, 2010, 08:16 PM   #148
stinkpickle
bitter clinger
Im shaking my head in disbelief. Worst carb ever is not an "honor" I want to have. Great pics BTW. Hey, ever figure out what happened with the runaway truck / turd incident ? made for great forum material.
Old October 28th, 2010, 08:22 PM   #149
deathbypsi
Brian R.
deathbypsi's Avatar
Just make sure that filter isnt letting anything thru it! Flush out the line before bolting the carb back on as well. Should be good as new tomorrow.
No new news on my truck. Still running fine and the smell is gone now...
Old October 28th, 2010, 08:35 PM   #150
stinkpickle
bitter clinger
cool. will do. cant believe it ran at all. call me (leave message) let me know where and when to pick up when ever you get done. thanks again.
Old September 11th, 2011, 10:25 PM   #151
stinkpickle
bitter clinger
Way behind in my posting. Heres some updates.
Got a best top tiger top.
[IMG][/IMG]
Did some work under the hood.
Added an electric water pump
some march serpentine pulleys with alternator and saggy pump brackets.
Got tired of dealing with my old holly street carb and went to a holly truck avenger
went to a square bore edlebrock intake
planning to convert to power steering in the near future.
Heres an update pic of the engine bay.
[IMG][/IMG]
Old September 12th, 2011, 09:46 AM   #152
deathbypsi
Brian R.
deathbypsi's Avatar
Wow big changes! Lookin good! Putting many street miles on it?
Old September 12th, 2011, 10:37 PM   #153
stinkpickle
bitter clinger
Thanks, no miles at all. Had the carb issues that kept me in the drive way. plan to have it ready to wheel by mid october. Gotta do a small body lift to accommodate the taller carb, convert to power steering and go to hydraulic clutch.
Old September 26th, 2011, 01:16 PM   #154
stinkpickle
bitter clinger
Fabbed up a winch/ saggy box bracket.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old June 17th, 2012, 08:39 AM   #155
stinkpickle
bitter clinger
Figure i should update this build thread. With the help of deathbypsi, I finally have this jeep tuned in and running smooth. Thanks again Brian. I finished my saggy swap, probably the largest driver comfort improvement I've made. I also went to a hydraulic clutch set up. Little improvements have made this thing fun to drive. We all like pics, so here you go.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Plenty to do still. I have to finish the roll cage, clean up, prime and paint. Gotta fix the sheet metal, straighten, fill in holes, apply por15, prime and paint it "harvest tan" . I have yet to instal shocks and Im missing a speedo, fuel and oil pressure gages. I would like to add a winch, a nt d44 with selectable locker in the rear and narrow 35" mud terrain tires.
Old June 17th, 2012, 09:07 AM   #156
motocrosstcw
motocrosstcw's Avatar
Originally Posted by tweak View Post
Wow, that this is sharp looking for still being stock. Most have been stored nice.
Im in awww over how clean it looks, great looking Jeep!
motocrosstcw is offline   Reply With Quote
Old June 17th, 2012, 10:24 AM   #157
deathbypsi
Brian R.
deathbypsi's Avatar
Love it! Once my truggy is done you gotta go out with our group one time..
Old June 17th, 2012, 10:44 AM   #158
stinkpickle
bitter clinger
Was thinking that coupla days ago. When you get going on the truggy, I want to come up and check it out.
Old June 17th, 2012, 10:46 AM   #159
stinkpickle
bitter clinger
Thanks. Taken a lot of work to get this far.
Old June 17th, 2012, 08:02 PM   #160
deathbypsi
Brian R.
deathbypsi's Avatar
Originally Posted by stinkpickle View Post
[/COLOR]
Im still finishing the turbo truck so the truggy is just a pile of parts rite now but your welcome to come by any sat-mon and check the mess out.
Page generated in 0.51448 seconds with 83 queries
