project (renamed) Old Iron cj2a - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2010, 05:23 AM   #101
stinkpickle
bitter clinger
stinkpickle's Avatar
Originally Posted by deathbypsi View Post
Lookin goood ! Just make sure water cant get inside your MSD thru the grommet where the wires come out {sticking straight up}.
Good point. gonna see if I have room to mount it horizontal, if not, black rtv on the grommet should help. when we going wheeling ?
stinkpickle is offline   Reply With Quote
Old March 22nd, 2010, 04:39 PM   #102
deathbypsi
Brian R.
deathbypsi's Avatar
As soon as I get this Bronco back together! Im goin crazy without something to go beat on.
Old March 22nd, 2010, 07:19 PM   #103
stinkpickle
bitter clinger
Im planning on taking this thing out to the airport to work the bugs out soon. need a wheeling buddy to tow me out when I break it.
Old March 27th, 2010, 10:13 PM   #104
stinkpickle
bitter clinger
Got it started today. Sounds really good. got my wire harness havnt installed it yet. I have something wrong with the distributer its making a funky loud clicking noise. Ill be sure to take care of that soon. Picked up my custom drive shaft cost me 65.00. Local guy fabs any thing from drive shafts to pulling tractor accessories. Ill post more pics when I get more done.
Old March 28th, 2010, 10:04 AM   #105
deathbypsi
Brian R.
deathbypsi's Avatar
Awesome Shane!! I would like to hear more info on driveshaft guy
Old March 28th, 2010, 10:37 AM   #106
89xjr
sommertyme 4x4
89xjr's Avatar
Great build, I've always wanted to build one. keep up the good work
89xjr is offline   Reply With Quote
Old March 28th, 2010, 12:43 PM   #107
stinkpickle
bitter clinger
Ill pm you his info later. His shop is out by Mabee off blue bush rd. He can do about any thing you need done except bend tube (got rid of the equipment). Got him to weld a crack in the engine block of my cj7 did an awesome job.
Old March 28th, 2010, 12:44 PM   #108
stinkpickle
bitter clinger
Thanks. Ill be sure to post some pics soon. Still have lots of work to do.
Old March 29th, 2010, 07:43 PM   #109
stinkpickle
bitter clinger
Got some work done today. worked on getting the wire harness installed- this is gonna take a while. I got this from e-z wire for 150.00. it has 12 circuits and it has a compact design for tight spaces.
[IMG][/IMG]
[IMG][/IMG]
Old April 2nd, 2010, 11:52 PM   #110
stinkpickle
bitter clinger
wire harness is routed and connected. every thing works. E-Z wire sent great, easy to read directions and schematics. replaced distributer this eliminated funky loud clicking noise. old one had a tweaked shaft. Ill post pics when I get the harness wrapped in split loom. now to figure out why thermostatically controlled fan wont turn on.
Old April 4th, 2010, 09:02 PM   #111
stinkpickle
bitter clinger
Worked on the jeep today. hooked up throttle linkage to the carb, worked on my thermostat problem. I concluded the thermostat is bad- back to summit it goes. Corbau seats come in tomorrow, gotta pick up gas peddle assembly from the junkyard, instal front drive shaft, finish front break lines, instal break, gas and clutch peddles tomorrow and it should drive.
Old April 4th, 2010, 09:24 PM   #112
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
looks great. wish I would have known you were going with an ez wire harness I could have hooked you up with a discount from a friend of mine who carries their products.
Old April 5th, 2010, 09:37 PM   #113
stinkpickle
bitter clinger
Thanks for the compliment. A deal on the harness would have been nice, thanks any way. Found some nice LED tail lights that come in 2a housing. Im really debating on whether to go flush mount LED or the 2a LED. The 2a LED would be vulnerable to breakage but would preserve the original look. 60 bucks through 4x4 hardware.
Old April 10th, 2010, 07:13 PM   #114
stinkpickle
bitter clinger
Got a few goodies the other day.
Went with the KNN extreme to get good air flow and I really didn't care to have a chrome or painted air cleaner lid. Gotta get some tall black valve covers new spark plug wires and some plug wire organizers to neaten up the engine compartment.
[IMG][/IMG]
I have to make seat brackets yet. should be done in a day or two. I love these seats! they're Corbues baja suspension seats. I got the short back version to try to keep the original look.
[IMG][/IMG]
Old April 11th, 2010, 08:25 AM   #115
stinkpickle
bitter clinger
Jeep drives... till fuel filter clogs with rust. Im treating the tank with some rust eater I got from tractor supply company. Treated the bottom so far and find it to be very effective. eats it down to the bare metal.
Old April 19th, 2010, 09:30 PM   #116
stinkpickle
bitter clinger
Been working on the Jeep. Got the passenger and rear seat installed. Had to make brackets for the front seats, rear seat bolted right in (rear seat will be recovered in black material later). Set the ignition timing. Engine runs and idles great. Still have a lot of odds and ends to do. Havnt done the axle upgrade yet, Im going to power brakes and will go with discs up front and drums in the back.I need to figure what pinion angle I can run at and weld on some new spring perches. I plan to go with a spring under set up.
Heres how it sits now.
[IMG][/IMG]
Made a shift knob. Thinking of cutting down shift lever, little too tall.
[IMG][/IMG]
Another angle
[IMG][/IMG]
Old April 20th, 2010, 04:49 AM   #117
deathbypsi
Brian R.
deathbypsi's Avatar
Dude I am jealous as shit!!! Lovin it!
I would hit those wheel wells with some black paint,bedliner or undercoating tho.
Old April 20th, 2010, 05:12 AM   #118
stinkpickle
bitter clinger
The back wells have por15, got to top coat them with the rubberized undercarriage stuff. Plan to get the front when I get more por15. I got to strip the chrome off the wheels and paint them too. I got a Bronco for sale, if you want another Bronco project.
Old April 20th, 2010, 08:38 AM   #119
deathbypsi
Brian R.
deathbypsi's Avatar
HA! The last thing I need is another project!
Old April 26th, 2010, 09:29 AM   #120
stinkpickle
bitter clinger
Update: Ive been driving it around a bit to work out some bugs. I still have the stock axles with 5.35 gearing. Im getting ready to go to a NT d30 up front and NT amc 20 in the rear. These will give me stronger, upgradable axles and a little wider track. I plan to put solid axles and a locker of some type in the amc 20. The "new" axles will have 3.54 gearing. Not sure if Ill like this gear size with the sm465 trans for road, trail and some sand. Constructive input on locker type and gear size is wanted.
Page generated in 0.35197 seconds with 83 queries
