project (renamed) Old Iron cj2a - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2009, 12:08 PM   #81
dreezy
Haggard Fab
dreezy's Avatar
After seeing a picture of your wife, I now understand the motor swap.
Old August 5th, 2009, 08:28 PM   #82
stinkpickle
bitter clinger
stinkpickle's Avatar
little work done so no pics.
stinkpickle is offline   Reply With Quote
Old August 7th, 2009, 05:05 PM   #83
stinkpickle
bitter clinger
Took the 2a to the muffler shop today. running true dual exhaust into flow master mufflers to get that "flowmaster" sound that I love.
Mean while, been working on the cj7 hijack. I call it the hijack because it hijacked the cj2a project temporarily. Just gotta put the oil pan and valve cover on the "new" motor bolt the engine and tranny together and drop in.
put some 31" bfgs on the 2a to see what it would look like.
Still got to do some fab work on the grill to house the radiator properly.
Old August 7th, 2009, 05:14 PM   #84
deathbypsi
Brian R.
deathbypsi's Avatar
That little thing looks badass!
Old August 7th, 2009, 05:31 PM   #85
stinkpickle
bitter clinger
lol. I knew you'd like those 31s. You should see it in person. the pics dont really do it justice. it sits up pretty high.
Old August 14th, 2009, 07:23 PM   #86
stinkpickle
bitter clinger
Update: waiting on a pilot bushing for the cj7 hijack jeep. Got the exhaust done 200.00 for labor. real tight fit, Ill get some pics up later for your amazement. Got a altinater today. checked out the starter situation, Currently I dont have one. muffler shop suggested using a mini starter (around 150.00) because of possible clearance issues and heat, the header is pretty close. so after measuring I determined a factory replacement starter should fit just fine. Heat might be an issue but ill fab up a heat shield to combat the heat. we'll see. Got to buy a starter, electric fan, a msd box and some other small items and it should run.
Old August 15th, 2009, 08:40 PM   #87
deathbypsi
Brian R.
deathbypsi's Avatar
Run over to Sams Speed Shop on Laskey & Douglas because he has the whole line of DEI heat wraps,blankets and tape that would work great for a starter.
Old August 16th, 2009, 01:39 PM   #88
stinkpickle
bitter clinger
thanks, Ill check it out.
Old August 19th, 2009, 06:50 PM   #89
stinkpickle
bitter clinger
Update on the hijack jeep cj7: finally got my pilot bushing in. Mated the new manual trans to the engine and droped them both in today. should get it started tomorrow. Going from auto to manual 5 speed and was a bit worried how to mount bell crank to fire wall and trans to skid plate so that everything is alligned correctly. Had a look and was supprised to see mounting studs for the bell crank already there and predrilled holes for the transmission mounts. Resuming work on project pickle next week.
Old March 4th, 2010, 08:40 PM   #90
stinkpickle
bitter clinger
update but no pics. uncovered the 2a from its winter hibernation. got the radiator mounted today and worked on some clearance issues. ordering my ignition, e-fan and buying a starter in the next week or two. should be running soon.
Old March 4th, 2010, 08:43 PM   #91
THR3
THR3's Avatar
cool jeep
THR3 is offline   Reply With Quote
Old March 6th, 2010, 10:35 AM   #92
stinkpickle
bitter clinger
Originally Posted by THR3 View Post
cool jeep
thanks, i have a coupla up grades planned after I get it running. Get a roll cage, upgrade the axles to something heavier duty, upgrade to power steering and brakes, hose some paint on.
Old March 13th, 2010, 08:10 PM   #93
stinkpickle
bitter clinger
I did work on the 2a over the week. got my fan, not very big (12") but is supposed to crank out 2,300 cfms. built a shroud for it, had to offset it so it could fit in front of water pump. I plan to go to a short pump eventually thatll give me some more room.
[IMG][/IMG]
[IMG][/IMG]
Got my ignition today as well.[IMG][/IMG] went to mount it on the fire wall but discovered various holes some from the factory (heater core), some from prev. owner. plan to patch over that tomorrow so i can properly mount the cdi box.
Heres a shot of my really tight dual exhaust.
[IMG][/IMG]
should be running soon!
Old March 14th, 2010, 09:28 PM   #94
stinkpickle
bitter clinger
bump for the new pics.
Old March 14th, 2010, 11:18 PM   #95
THR3
THR3's Avatar
looking forward to more pics
Old March 15th, 2010, 12:07 PM   #96
dreezy
Haggard Fab
dreezy's Avatar
LOL. I wish I could get her to understand all the time and effort spent doing this project.
I dont think you get what I was trying to say...
Old March 15th, 2010, 06:26 PM   #97
stinkpickle
bitter clinger
built battery box, installed cdi box, carb, sorted out some emissions/ vacuum issues. nothing too exciting. one day closer to start-up.
Old March 15th, 2010, 10:12 PM   #98
suckyjunk
suckyjunk's Avatar
cool build
suckyjunk is offline   Reply With Quote
Old March 21st, 2010, 08:17 PM   #99
stinkpickle
bitter clinger
Saturday I routed my fuel lines, hooked up radiator and installed distributer. I also purchased a brake booster, master cylinder and pedal assembly out of a 92 xj. should fit nicely. waiting on shackle conversion kit so I can get rid of the C style shackles now hooked up to my leaf springs also waiting for my wire harness from EZ wire. Heres how the engine bay looks now.
[IMG][/IMG]
[IMG][/IMG]
Old March 22nd, 2010, 01:41 AM   #100
deathbypsi
Brian R.
deathbypsi's Avatar
Lookin goood ! Just make sure water cant get inside your MSD thru the grommet where the wires come out {sticking straight up}.
Page generated in 0.56950 seconds with 83 queries
