Honda three wheeler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2009, 11:05 PM   #1
Jdc215
Jdc215's Avatar
Default Honda three wheeler
i have a honda ATC 350X. unfortunatly it has a bad seal on the drive shaft that i cant figure out how to fix, i also need to tighten the chain and two of the three bolts holding the oil filter cover on broke when i tried to reemove it, and thanks to the chain being loose there is a small hole in the ceank case.
it sounds like alot of problems but im not too good with small engines and atv stuff. if there is anybody out there who would be willing to help me fix these or would be willing to fix it for a price let me know.
Jdc215 is offline   Reply With Quote
Old February 21st, 2009, 09:54 PM   #2
Jdc215
Jdc215's Avatar
bump
Old February 22nd, 2009, 06:42 PM   #3
booblinker
Sore and Tired 24/7
booblinker's Avatar
For the hole in the crankcase you either need a new case, or clean it really good and rough it up with sandpaper and jb weld it. On the oil filter cover you are going to have do drill the bolts, and extract them, or jsut totally drill it out and re tap it. For the chain you should be able to loosen the big bolt that holds the swing arm to the frame, and then tighten the tensionors on the rear axle, at least that how it is on my 200x.
Old February 25th, 2009, 11:01 AM   #4
Jdc215
Jdc215's Avatar
i was able to extrct the bolts, and i put the jb weld on last night but its still tacky so i put a small heat lamp on it, i think to tighten the chain i meed some kind of spanner wrench but i dont know where i would get one. there are some bolte on the back of the swing arm and a fixture that looks like it needs to be rotated.
Old February 25th, 2009, 05:32 PM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
Check out 3wheelerworld.com probably find a lot more info there.
Old February 25th, 2009, 08:54 PM   #6
Jdc215
Jdc215's Avatar
i have but i didnt find anything concerning those spacific problems
Old February 25th, 2009, 11:04 PM   #7
stuckinthemud
stuckinthemud's Avatar
if you send me a picture of the swingarm in the back where those bolts are i can probably help you we work on alotta old honda 3wheelers and 4wheelers just cant remember if that one is set up same way as the 250r's
stuckinthemud is offline   Reply With Quote
Old February 26th, 2009, 07:26 PM   #8
booblinker
Sore and Tired 24/7
booblinker's Avatar
I Think the 350x is shaft driven, and the 250r is chain, but i could be wrong.
Old February 26th, 2009, 11:00 PM   #9
Jdc215
Jdc215's Avatar
im pretty sure they are all chain driven, mine has a chain and all of them i have ever seen have chains, i wish it had a shaft for ground clearance issues and they dont have to be tightened. i got that all figured out though.
now i just need to replace the brakes pads front and rear, buy headlight bulbs, get the new brackets for the swing arm skid weelded on and replace the clutch (mine slips in 5th and 6th gear sometimes) i dont know if thats normal or not but it does so i think i need to reeplace it.
Old March 10th, 2009, 09:45 AM   #10
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Clutch slippage in 5th or 6th indicates that it is worn... Replace the friction plates, and I would also change the springs (go with a heavy duty spring kit)... I believe you have to soak the plates in engine oil for 24 hours.
If the steel plates look glazed or burnt, I have heard of guys using a piece of plate glass with some ultra fine wet-sand paper and some oil and laying the discs on it and moving them around in a circular motion (not spinning, more like the old "Spirograph" type circles) to "re-dress them" You will want to be careful not to remove too much material, I would think... They should end up with crosshatching similar to when you hone a engine cylinder.
If the basket is worn from the clutch plates riding on it, you may need to replace it, as it could cause the slipping as well.
Torque for the center nut is 72-87 ft-lbs
and for the 4 bolts that hold the lifter plate 7-10 ft-lbs
That is right from the manual...
Good luck, J
Old March 10th, 2009, 03:58 PM   #11
booblinker
Sore and Tired 24/7
booblinker's Avatar
When my honda slipped, I just sanded the palates with some 200 grit, Not really the right way but I rode the shit outta that thing, probably put a few hundred miles on it and i was overweight for the bike and it still wasn't slipping when I sold it.
Old March 11th, 2009, 12:00 PM   #12
Jdc215
Jdc215's Avatar
i plan on replacing the clutch next, then ill put in neb breakes front and rean, ten a new carb (theres nothing wrong with mine but it will need rebuilding and the asshole who owned it before me stripped out all the screws holding it together. i might try to xtract and replace them first though), and then headlight bulbs to round things out.
Old March 11th, 2009, 04:31 PM   #13
booblinker
Sore and Tired 24/7
booblinker's Avatar
You forgot you need a turbo too.
Old March 11th, 2009, 08:25 PM   #14
Jdc215
Jdc215's Avatar
are you joking, i have never heard of one for it and i wouldnt have the money for it even if there is such a thing, but if there is id be intrested with redurds to futrue modifications.
Old March 11th, 2009, 08:26 PM   #15
BigBird
BigBird's Avatar
Float bowl ones can sometimes be removed with Needlenose vise-grips...
Old March 11th, 2009, 10:37 PM   #16
booblinker
Sore and Tired 24/7
booblinker's Avatar
Yea I was kidding, no turbo kits for those, but you can make a turbo fit on anything if you try hard enough.
Old March 17th, 2009, 11:22 PM   #17
Jdc215
Jdc215's Avatar
thats true. i have been beating the piss out of it the past week and i notice it slipping in second gear some times. i think its time for a new clutch.
Old March 29th, 2009, 04:55 PM   #18
Jdc215
Jdc215's Avatar
i adjusted the clutch and now i don't have any slipping at all so now i just need new brakes, headlights and some replacement screws for the carburetor.
Old April 7th, 2009, 10:14 AM   #19
Jdc215
Jdc215's Avatar
yester day i had a bl;ast in the snow, tore it up. right now i just need ot readust the chain, adjust the carb, then buy light bulbs and brake pads.
Old April 25th, 2009, 10:21 PM   #20
Jdc215
Jdc215's Avatar
rode with some friends on dirt bikes today for 3 hours, i realized its pretty slow by todays standards but i still had alot of fun and there were some things i did they couldnt do.
Page generated in 0.54276 seconds with 83 queries
