32HP 992 horizontal shaft NG/LP engines for cheap. *PRICE DROP* scrapping soon - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 18th, 2009, 06:54 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default 32HP 992 horizontal shaft NG/LP engines for cheap. *PRICE DROP* scrapping soon
These are engines that no longer "met spec" while they were under warranty. The service tech that swapped these out wasn't keeping notes on the engine of what was wrong and what wasn't. If you were to buy two of them you would probably have 2 working engines, or at least enough parts to build 1.9 working engines
They are all complete, including automotive delco starters on them. They have to be useful for something.. They will run off natural gas or propane, and you flip a switch to slide the propane nozzles into place in the carb. It's a really nice setup. These engines are designed to run at 3600 rpm's.
Located in auburn hills, and I'll sell them for $100 a piece. (I have a lot of them)
I pay over $1100 for these.
Located in Auburn Hills.
32 hp Generac Engine
Displacement 992
Bore 90mm / 3.54"
Stroke 78mm/ 3.07
Compression Ratio 8.6:1
Lubrication Full Pressure
Oil Capacity 2.2L / 2.33 Qts
Model 0050551
Ships Truck Freight
Specifications
-Horizontal Shaft
-V-Twin Cylinder
-Air Cooled
-OHVI Industrial Engine
Standard Features
• Full Pressure Lubrication (Automotive Type Gerotor Oil Pump)
• Automotive Type Oil Filter
• Engine Oil Cooler, Utilizes High Velocity Flywheel Fan Air
• Low Oil Pressure, Normally Closed, Switch (Not Connected)
• High Torque Industrial 12V Solenoid Shift Electric Starter
• Cast Iron Liners
• Large Hardened Crankshaft Bearing Journals
• Special Alloy Sleeve PTO and Flywheel End Bearings
• Hardened Camshaft, Helical Cut Gears
• Hardened Valve and Valve Seats
• Cam Ground Pistons Skirt (Elliptical)
• Chrome Compression Ring
• 3 Piece Automotive Type Oil Ring
• Electronic Ignition, 2-Barrel Carburetor
• Fuel Pump, Vacuum Operated
• Heavy Duty X-Torqฎ Governor with Thrust Needle Bearing
• Fuel Shut-off Solenoid
• Industrial Multi-Stage Air Cleaner
• Closed Loop Breather System
•Fill Tube with Dipstick
• Rotating Flywheel Cooling Air Screen
• Removable Fixed Flywheel Debris Screen
• Engineered High Volume Flow Muffler, Tube Outlet
• Fuel Filter, No-Tank
• 12 V, 20 Amp Regulated Charging System
• Wire Harness with Packard Connector
• Remote Throttle Control, Remote Choke Control
• 1 7/16" diameter Crank
clarkstoncracker is offline
Old February 18th, 2009, 07:38 AM   #2
jonzer12
Do you have any that run on regular gas? Is the crank tapered or keyed?
jonzer12 is online now
Old February 18th, 2009, 07:41 AM   #3
89Jeepy
89Jeepy's Avatar
Do you have any that are running? and if so how much? Definitly interested!
89Jeepy is offline
Old February 18th, 2009, 08:36 AM   #4
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
cranks are tapered with a 3/8" 24 thread in the end.
BigBlkYJ 355 is offline
Old February 18th, 2009, 11:36 AM   #5
clarkstoncracker
lol
I'd guess that over 1/2 of them run fine, and the other half need a governor, maybe a starter, maybe a choke.
I'm not going to test them because it would cost me more money to set it up to test it then the price I'm asking.
I have many more engines that aren't complete, and no matter what you find wrong with one of the engines, I'll have a part to fix it.
Old February 18th, 2009, 11:39 AM   #6
clarkstoncracker
lol
Sure, buy one of my engines then call my buddy Todd over at US Carburetion and buy a conversion kit.
http://www.propane-generators.com/
Old February 18th, 2009, 05:20 PM   #7
4x4klein
Weapon K
4x4klein's Avatar
I'd love to find a use for one of these!
4x4klein is offline
Old February 19th, 2009, 12:13 AM   #8
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
if i can figure out the carb change im in oh the go cart i could have
unclebeaner is offline
Old March 4th, 2009, 08:16 AM   #9
clarkstoncracker
lol
why? Put a fork lift propane tank on your go cart and it's all set.
I'll sell these for $70.00 a piece now, and I'm going to bring all 20 or so I have left to the scrap yard on friday. So if you want one, let me know asap.
1st come, 1st serve, you pick out the one you want.
Old March 4th, 2009, 10:16 AM   #10
dreezy
Haggard Fab
dreezy's Avatar
If any one from the west side is headed to pick one of these up I would like to get my hands on one.
dreezy is offline
Old March 4th, 2009, 10:28 AM   #11
89Jeepy
89Jeepy's Avatar
I might take you up on that offer... i really really want a couple, ill let ya know on here before friday for sure, thanks for the heads up Kracker
89Jeepy is offline
Old March 4th, 2009, 05:04 PM   #12
4x4klein
Weapon K
4x4klein's Avatar
About how much do these weigh each?
4x4klein is offline
Old March 4th, 2009, 09:51 PM   #13
clarkstoncracker
lol
down to 7 of these!!!!
Old March 4th, 2009, 09:51 PM   #14
clarkstoncracker
lol
not sure, like 100 pounds or so.. all aluminum.
Old March 4th, 2009, 09:58 PM   #15
Sandals
Fucking Zen as Shit
Sandals's Avatar
i'll buy all 7 left if you throw in a rotational electricity maker with one of them
Sandals is offline
Old March 5th, 2009, 06:06 AM   #16
clarkstoncracker
lol
Do the stator and rotors have to be in working condition?
Old March 5th, 2009, 11:25 AM   #17
Sandals
Fucking Zen as Shit
Sandals's Avatar
that would be the preferred way to receive them, oh and throw in a voltage regulator too :)
Sandals is offline
Old March 5th, 2009, 05:32 PM   #18
89Jeepy
89Jeepy's Avatar
Good day from the west side willing to pick up some on friday if you have any left. Give me a call in the morning with how many you have left and where you are located, I can be there around 2:30 in the afternoon. 616-293-4931 i hate to see a good engine go to scrap. ~Jesse
89Jeepy is offline
Old March 16th, 2009, 10:42 PM   #19
mudhead
PM sent
mudhead is offline
Old March 18th, 2009, 05:42 PM   #20
racinja
racinja's Avatar
do you have 2 left? or did you sell or scrap them already? i could pick up tomorrow
racinja is offline
Powered by: vBulletin, Copyright ฉ2000 - 2012, Jelsoft Enterprises Ltd.
Page generated in 0.47380 seconds with 84 queries
