03 Ranger lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2009, 12:08 PM   #1
PVA DAVE
PVA DAVE's Avatar
Default 03 Ranger lift
I am looking for an inexpensive way to correctly lift an 03 extended cab Ranger for a customer. Seems all of the "kits" are outrageous for this truck. Has anyone on here done this? Bought one? Just trying to save a newbie to the sport some money if possible. Is there an affordable kit out there? The ones I have found were $2400......seems like ALOT to me. It will not be for hardcore off-roading, maybe some trail riding and wants his truck to look different than all the others. 3 to 4 inches would be great.
PVA DAVE is offline   Reply With Quote
Old February 17th, 2009, 07:08 PM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
3-4 is going to be a little tough for not alot of $$$. Though there is a way.
Front - simple torsion bar crank, good for about 1.5", but can be made higher, generally past 1.5" and it gets a little stiff for most and has a tendency to "top-out" (as best I can put it) as opposed to "bottoming-out". You might be able to get 2" out of it though. 1.5" and under, almost no one has complaints.
Rear - 1) Shackle lift. Essentialy a 2" Chevy drop shackle flipped over, since Rangers hangars are backwards from chevy's. Roughly 1" lift total, and the spring will be happier and ride a little nicer. 2) Explorer rear leaf springs. These will net about 1" - 1.5". All these need to work is the center bolt flipped over. Explorers are SUA and Rangers are SOA. The only real difference in the springs is the explorers have a bit more arc.
Then to get the last little bit, a 1" Body lift. You could do 2" but it may start to get that "body lifted look", which I think looks terrible. But 1" should be able to be made relatively unnoticeable, relatively cheaply, and shouldn't require too much modification otherwise.
This would net roughly 3" overall and should be able to fit 33"s nicely, but not far enough that 31's look like they still should be under there.
That is by far the cheapest option to get that amount of lift.
Old February 17th, 2009, 08:32 PM   #3
liftedlq9
Dune Slut
liftedlq9's Avatar
^ seems to be the best way imo. I have a buddy with an 03 with the 6in kit that takes out the tbars and replaces it with a coil over front. Nice kit, but it was very pricey!!
liftedlq9 is offline   Reply With Quote
Page generated in 0.86390 seconds with 32 queries
