fixing backlash on 8.8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2009, 09:50 PM   #1
94KOTA
Buy American!
94KOTA's Avatar
Send a message via AIM to 94KOTA
Default fixing backlash on 8.8
Hello
I have a 94 explorer with 3.73s and 31s...seems as though the backlash is gettin a little more worse...if the gears were not chipped and still in good condition how would you go about adjusting?...shims?
thanks
94KOTA is offline   Reply With Quote
Old February 16th, 2009, 10:01 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
what are the symptoms why do you think its a back lash problem
Old February 17th, 2009, 04:16 PM   #3
94KOTA
Buy American!
94KOTA's Avatar
im not really sure but i thought this was a symptom...putting it into reverse or drive it jerks kinda hard....but shifting thru gears its perfectly smooth...backlash possibly??
thanks
Old February 17th, 2009, 04:24 PM   #4
deathbypsi
Brian R.
deathbypsi's Avatar
I would lean more towards the spider gears being wore. If the backlash was way out of spec from a wore ring and pinion you would hear whining from the rear.
Old February 17th, 2009, 04:43 PM   #5
BlackBetty97
We Like it Loud
BlackBetty97's Avatar
Another thing to check would be the slip yoke on the driveshaft. They have a tendency to bang around if they are not greased, generally going into drive from park.
BlackBetty97 is offline   Reply With Quote
Page generated in 0.23229 seconds with 38 queries
