banshee questions!!!! HELP! - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 17th, 2009, 07:36 PM   #21
Blackbeast2
Hardcore since 84
you buy it for 1000 and throw in 600 and ill trade you my 85cj7 which used to be my dd now a trail rig, which has never been abused.
Blackbeast2 is offline   Reply With Quote
Old February 17th, 2009, 07:58 PM   #22
Davidc093
im thinkin the same coop
Davidc093 is offline   Reply With Quote
Old February 17th, 2009, 08:56 PM   #23
B
NINJA DEALER
B's Avatar
Originally Posted by Davidc093 View Post
he says he ran it 50 to one....also he said today that it pretty much has every bolt on accessory it can, but no motor work done be sides re-jet on the carb.....is this good or bad? im going to check it out this weekend...thanks for the hellp
Bump
since you said it had after market PIPES* then you better hope he re jetted it. or it will blow up soon. if you run it 50:1 run a good oil, (not yamalube 2R) ie: klotz, ect.. make sure the carbs are in sync, banshees run very well when properly jetted and tuned. being a mechanic im suprised your having an idiot salesman give you advice
B is offline   Reply With Quote
Old February 17th, 2009, 10:22 PM   #24
gatesboy
i mx raced banshee's for several years if you use good 2-stroke oil and the higher octain gas the better and keep the air filer clean it will last for years put a pro-flow kit in the air box and use a foam filter will help
gatesboy is offline   Reply With Quote
Old February 18th, 2009, 12:49 AM   #25
littleredzj
i like turtles.
littleredzj's Avatar
$1000.01 still stands ill even throw in 3 broken yo-yo's and half chewed piece of orbit gum...
littleredzj is offline   Reply With Quote
Old February 18th, 2009, 09:05 PM   #26
Davidc093
right well ill let you all know how it is when i drive it this weekend ill be the first to admit 2 strokes are my weak point so if i half to listen to a salesman ill do what i got to do!!!! thanks for the hellp!!!
bump
Page generated in 1.86639 seconds with 41 queries
