banshee questions!!!! HELP! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2009, 03:28 PM   #1
Davidc093
Default banshee questions!!!! HELP!
whats up guys just wanted some input on any info you have on banshee's....im thinking about buying one off of my buddy from school and i have no clue what to look for i havnt even personaly looked at it yet of coarse im going to drive it and look it over first but i dont really know what to look for ive ownd quads my hole life but never a 2 stroke so any help on it would be great he says it's eaither a 2000 or 2001 in great shape thats all i know as of right now...so let me know of any questions i should ask or anything i should look for im probably going to check it out this weekend...thanks alot
Dave
Davidc093 is offline   Reply With Quote
Old February 16th, 2009, 05:08 PM   #2
94zj4.0
zj to xj to wj
94zj4.0's Avatar
Find out if its stock or built? how much does he want? does it have a clear title? you can pick up a clean one for $1500 to $2500 off of craigslist. If its stock make sure it hasnt been abused or you will be rebuilding soon!!! if its been built find out what EXACTLY has been done (port and polished,new pistons,clutch,etc.) other than that if it runs good go for it. If its your buddy hope you can trust him! Good luck i miss my shee
94zj4.0 is offline   Reply With Quote
Old February 16th, 2009, 05:19 PM   #3
Davidc093
yeah its a good deal he isnt really selling it unless its someone he knows he's selling it for 1000 says the carb has just been rebuilt or re-adjusted i forget and it has a pipe besides that its stock i really want a cheap trail rig but for the money i think this will be my best bet for a good time a silver lake! thanks for the info any others out there want to coment it would be appreciated!!!!
bump
Old February 16th, 2009, 05:22 PM   #4
special k
special k's Avatar
check the compression on it for shits and giggles. i wanna say it should be around 90 psi on both cylinders, i think thats what my 06 is. also like stated before, if any mods are done, make sure you find out everything, and ask what jetting is it it, and wat temps and altitueds it is jetted for to get an idea of what changes may need to be made.
Old February 16th, 2009, 05:22 PM   #5
94zj4.0
zj to xj to wj
94zj4.0's Avatar
$1000 bucks you cant go wrong you can sell it for parts and make your money back!!
Old February 16th, 2009, 05:57 PM   #6
Davidc093
thats what i figured also i always noticed when i see 2 strokes on the trail alot of times they smoke (exhaust) is that normal i no the 2 strokes usualy do during start up but will they when there warmed up also?let me know if possibel thanks
bump
Old February 16th, 2009, 06:09 PM   #7
Davidc093
bump
Old February 16th, 2009, 06:11 PM   #8
hondadirtracer
Skymaster
hondadirtracer's Avatar
yes they will smoke because they burn gas and oil
hondadirtracer is online now   Reply With Quote
Old February 16th, 2009, 08:32 PM   #9
Davidc093
bump
Old February 16th, 2009, 08:35 PM   #10
special k
special k's Avatar
the smoke should be less once warm. my banshee stock and with pipes smokes very little even at WOT when warm
Old February 16th, 2009, 08:56 PM   #11
Davidc093
thanks for the help everone hope to see ya's at silver lake i plan on going the second weekend it opens even if i have to trailor the f-150....but with gas prices lets hope for the banshee to be in good shape!!!
Old February 16th, 2009, 10:39 PM   #12
jeepguy74
jeepguy74's Avatar
use good oil such as belray or klotz r50
i used klotz beanol mixed 40-1 one bottle to 5 gal of gas ran it hard as hell for2 years and never had a problem also ran another banshee on belray same way for 3 years......it will cut down on fouled plugs and run alot better ... banshee is a great quad and you will love it
Old February 16th, 2009, 10:42 PM   #13
special k
special k's Avatar
ya i run my banshee 40:1 with klotz benol, keeps shit clean and smells awesome, but its expensive, think its like 11 bucks a pint, btw. only thing about benol is dont run it in the winter, it separates and will not function as a lubricant any longer
Old February 16th, 2009, 10:50 PM   #14
littleredzj
i like turtles.
littleredzj's Avatar
the reason alot of them smoke is that modern oil can be mix at 40:1, 50:1, and theres even an oil i used that is recomended at 100:1 but the owners manuals say to mix at like 26:1 which with todays oils is way too much and thus causes smoke, also most quad that have self mixing system mix it at a bads ratio.
as far as what too look for:
for $1000 bucks for an 01 if it runs its worth it.
banshee take alot of kicks to start with low comp. so if it starts right up it should be good.
on a side note ill give you $1000.01 for it
littleredzj is offline   Reply With Quote
Old February 16th, 2009, 11:02 PM   #15
special k
special k's Avatar
hell for that price even if it needs a top end you can get a wiseco top end rebuild kit for less than 400 bucks i think, so when you think about it, a 1400 good condition banshee is still cheap
Old February 17th, 2009, 04:03 PM   #16
Davidc093
he says he ran it 50 to one....also he said today that it pretty much has every bolt on accessory it can, but no motor work done be sides re-jet on the carb.....is this good or bad? im going to check it out this weekend...thanks for the hellp
Bump
Old February 17th, 2009, 04:11 PM   #17
B
NINJA DEALER
B's Avatar
x2 on the compression check, but it should be about 130 psi per cylinder, not 90. if it has high compression domes ie: a cool head it will be higher, make sure both cylinders are the same (or close ) for $1000 if it runs and drives your good on the price, but from the way it sounds you dont know alot about working on stuff, so i would buy this and either sell it or trade it for a reliable four stroke machine for less maintence and easier turn key operation. just my .02
B is offline   Reply With Quote
Old February 17th, 2009, 06:10 PM   #18
Davidc093
no i have had 4 strokes for my hole life and rode a banshee last year at silver lake and it blew my mind away and it was stock....ive been a diesel tech for the past five years if that counts for "working on stuff" but im not sure....thanks again for the help and i do plan on doing the compression check!!
Old February 17th, 2009, 07:26 PM   #19
Davidc093
bump
Old February 17th, 2009, 07:32 PM   #20
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
a grand?!?! buy it, who gives a shit if it needs to be rebuilt.
Page generated in 0.38275 seconds with 83 queries
