1997 1 Ton chevy Cab aand chassis SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2009, 01:36 PM   #1
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Default 1997 1 Ton chevy Cab aand chassis SOLD
1997 Chevy
cab and chassis dually
454
4l80e
white
gray interior
i have been using this as a dump truck and if some one wanted it i would need a week or so to get the dump box taken off of it and out on my 2001 that im selling.(selling one or the other)
located in Fenton
1750
hosejockey4506 is offline
Old February 16th, 2009, 03:08 PM   #2
four_by_ken
Need a strap?
four_by_ken's Avatar
How many miles?
2wd?
four_by_ken is offline
Old February 16th, 2009, 03:58 PM   #3
hosejockey4506
Visiting Admin
yes 2 wheel
125,330 miles
i have one camera phone pic of the truck
Old February 16th, 2009, 11:36 PM   #4
mudhead
is it in good running order
mudhead is offline
Old February 17th, 2009, 09:24 AM   #5
hosejockey4506
Visiting Admin
yes use it daily, i get a check engine light once in a great while and every time i have checked it its a down stream O2 sensor i have just not taken the time to change it out.
Old February 23rd, 2009, 11:02 AM   #6
hosejockey4506
Visiting Admin
put a new pitman arm on and its getting a alignment. had a bit of a wiggle in the front end.
Old March 17th, 2009, 05:41 PM   #7
Wheelingcheap
Wheelingcheap's Avatar
Nice truck, if you need a Flatbed for it, or if whoever buys it needs a Flatbed, I have a 8ft x 9ft long heavy duty bed I took off of my F350 dually that would fit it. I'll make you a great deal on it! It is not homemade. 248 280 0747, Matt. Bump!!
Wheelingcheap is offline
Old March 17th, 2009, 06:44 PM   #8
hosejockey4506
Visiting Admin
Also this is not just a 1 ton pick up with the bed removed
its was sold from the factory as a cab and chassis it has a larger frame and dual tanks and some other little things that make it a nice heavy duty truck
Old March 18th, 2009, 12:12 PM   #9
hosejockey4506
Visiting Admin
trades partial or full
skid steer trailer
wrecked or blown up tj
d60 front axle
sthil chain saw 031 or bigger
14 bolt rear axle 99 newer preferred DRW
17 inch aluminum bead locks 8 on 6.5
or if you want to buy this on a credit card i can just have you order me some stuff i need
Old March 18th, 2009, 12:14 PM   #10
crassell
crassell's Avatar
what kind of d60
crassell is offline
Old March 18th, 2009, 12:16 PM   #11
hosejockey4506
Visiting Admin
any srw axle that is 8 on 6.5 bolt pattern really doesnt matter much
as long as it is in working condition with brakes
Old March 18th, 2009, 03:15 PM   #12
Grassman
2jz specialist
Grassman's Avatar
is that a plow mount on the front? (yes i know its 2wd)
Grassman is offline
Old March 20th, 2009, 11:49 PM   #13
hosejockey4506
Visiting Admin
yes
Old March 23rd, 2009, 07:57 PM   #14
hosejockey4506
Visiting Admin
bump
Old March 23rd, 2009, 08:01 PM   #15
gmotox
gmotox's Avatar
pm sent
gmotox is offline
Old March 29th, 2009, 07:38 PM   #16
hosejockey4506
Visiting Admin
First pic is just of overall drivers side
pic of drivers door, right in the center of the bottom of door aproximatly 6 inches of surface rust on bottom edge
Drivers rocker i circled two small surface rust spots that are there
passenger side overall
passenger side rocker
bottom of passenger side door rust on the bottom edge
passenger door, dent was pushed back out but paint flaked and some small rippling where dent was.
previous owner had a visor on the truck i took it off but put the screws back in so it wouldnt leak
passenger frame, dump frame is the upper two pieces that would be removed
rear of frame
passenger side frame
let me know if you want more pics
Old March 30th, 2009, 03:56 PM   #17
hosejockey4506
Visiting Admin
Sold
Page generated in 0.27953 seconds with 74 queries
