snap on ya212a all better! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 15th, 2009, 11:27 PM   #1
1badzuk
1badzuk's Avatar
Default snap on ya212a all better!
i just bought this welder it welds poor at best
highest setting will not burn 1/16
gun and ground in correct recepticals
voltage selector set to 230 not 208 (also tryed 208 setting no luck)
power at plug 240
power at switch in welder 240
power after switch(with gun trigger pulled) 235
checked all 4 diodes all have continuity in only 1 direction as needed
load tested 4diodes all check fine what could be my problem? what am i missing?
1badzuk is offline   Reply With Quote
Old February 16th, 2009, 12:05 AM   #2
dragtruk
Questionable..
dragtruk's Avatar
Send a message via AIM to dragtruk
Did the previous owner weld aluminum? if so he would have had to switch polarity...
dragtruk is offline   Reply With Quote
Old February 16th, 2009, 12:10 AM   #3
1badzuk
1badzuk's Avatar
has spool gun unused polarity is good(tryed it wrong also)
also the gas is on and flowing well
it acts as if its welding "cold"
i dont think its a gound problem etheir you stike the wire on the clamp and it barley sparks.
Old February 16th, 2009, 03:22 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I would be looking at the circut you have it on. if its a 240 volt how many amp is it? sounds like you need a 50 amp circut if you have it wired for a 30 amp. it would run but very weak. secondly check your cord to chassie connections. it could also be an issue.
if by chance yours has electronic channels to switch between try changing channels. I noticed on a couple of our millers they have bad channels and won't run a start cycle and the wire burns back into the tip on the first trigger pull.
Yetti
Old February 16th, 2009, 05:23 AM   #5
jeepnxj96
jeepnxj96's Avatar
check polarity, if is it was set up for flux core at some point the polarity would have been changed, at least that is how it was on my 110 wire welder.
Old February 16th, 2009, 01:56 PM   #6
1badzuk
1badzuk's Avatar
i checked all of that suff i just broke down and had it sent to a repair shop waiting for the response
Old February 19th, 2009, 07:32 AM   #7
Red Barn Customs
TGW SUPER STAR
Red Barn Customs's Avatar
If all else fails call this shop called CK Systematic, ask for Don. They build most of the welders that bare the snap on name. They helped me diagnoise my snap on welder over the phone and sent out parts right away. Good luck, let me know if this helps you out.
Red Barn Customs is offline   Reply With Quote
Old February 19th, 2009, 08:03 AM   #8
1badzuk
1badzuk's Avatar
i brought it to rsv welding in gr he tested it and it was fine. my wires in the garage were good enough for my hf welder but not enough to get this beast to arc proper
Old February 19th, 2009, 10:03 AM   #9
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
what amp is your service in your garage
Page generated in 0.42265 seconds with 50 queries
