post your gear ratios - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 15th, 2009, 04:24 PM   #1
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
Default post your gear ratios
may be helpful info to have somewhere if people are considering t-case gears/axle gears etc. also state if you run it on road and how it does at highway or near highway speeds. (tire size also)
currently i am stock everything so i have nothing to contribute cause mine doesn't run.
i plan to do 4.10's toyota axles with 6.5:1 t-case gears in samurai with 35" tires
jeepman784 is offline   Reply With Quote
Old February 15th, 2009, 07:27 PM   #2
karl214
Default gear ratio's
My DD is running 4:30's from a 95 Tracker that had an automatic trans. The 5:12's are waiting for warm weather, all stock gears in transfer case with a 5 speed.. The 94 Sidekick hasn't been driven YET.. It's all stock gears and such, just a 3 inch body lift 1 1/2 spring boosters and 31-10.50 tires
karl214 is offline   Reply With Quote
Old February 15th, 2009, 07:47 PM   #3
crazymays77
95 geo tracker auto with 5.13 gears in the axles and a 4.24:1 reduction kit in the t case. its off road use only. running 31 inch tires and homemade lift kit. does pretty good it 2wd but 4 low in 1st gear it runs 3000 rpms and the speedo doesnt move. if i put it in drive i hit 3000rpms at 15 mph. does really good in the mud so far just need a new motor to really find out what it will do.
crazymays77 is offline   Reply With Quote
Old February 15th, 2009, 08:01 PM   #4
scottie
Eye candy
scottie's Avatar
Samurai
3.73 axles
4.16:1 tcase
31's
do drive it on the road often, could be lower.
so i guess that gives me a 56:1 overall ratio...
Old February 15th, 2009, 08:03 PM   #5
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
Default izook.....GROUCHE
the one in my avatar has 5:38's and a 6.5to1 tcase and 32x11.5x15 swampers
about 50 mph tops with a tailwind
1600 8 valve supercharged sami trans and airlockers
spr_chicken is offline   Reply With Quote
Old February 15th, 2009, 08:39 PM   #6
A4X4SPIT
A4X4SPIT's Avatar
I have 2 samurai/tracker based rigs they have really similar gearing both have dual transfer cases (modified tracker as ft case& stock samurai as back case)when I do the gear math I dont get as good a result as a set of transfer case gears would get me but I like to build my rigs out of what I have rather than what I could buy(more time than money)
95 tracker 4dr 4spd auto :
1st gear2.826 to 1 X tracker t/clow 1.82 to 1 X sami t/c low2.268 Xrip4.62 to 1 =finaldrive ratio53.5 to 1
spitfire samurai frame 16v 5spddual cases
1st gear3.65 x 1st t/clow1.82 x2nd t/c low2.268 xrip 3.54=final drive ratio 53.4
stock samurai
1st gear 3 .652 xt/c low2.268 xrip 3.73 =30.7
my tracker stock:=23.7
crazymays 77 tracker would have 61.5 to 1 which is probably more desirable than my
53.5 to 1 but I have a bunch of gearing oprions plus i like the bewilderes look when someone notices 3 shifters
A4X4SPIT is offline   Reply With Quote
Old February 15th, 2009, 10:35 PM   #7
jeepman784
jeepman784's Avatar
are you using a RingR or other vendor type setup? or something custom?
the elusive suzuki dual case setup haha
some boards guys are talkin 200+:1 ratios not being low enough... i say B.S. my toyota had ~80:1 and would crawl everything i had it on (nothing toooooo xtreme, but rocks and stuff out in yellow creek) granted the 22re will pull a little bit more, but i think that sometimes crawl is a little bit overdone just to have web wheel status haha
if i go 6.5's it'll give me 100:1 with an 8v 1.6. i am quite certain that'll get me most places that i need to go, and the hi range reduction should keep it streetable
Old February 16th, 2009, 04:04 AM   #8
A4X4SPIT
A4X4SPIT's Avatar
basically I use a stock tracker case w/the ft output cut off & the hole welded closed and a stock sami case hooked to the rear outputof the tracker case mounted so its lined up straight and a single ujoint jack shaft (basically rearslip yoke sami ujoint flange) this set up gets me to where I am gear wise for cheep even if I factor in value of a sami case
if I put a set of 6.5gears in the sami case Id have 152.8to 1 final drive but Im pretty happy with how my rigs work & Ive got 35"tire on these rigs
I dont need some really outragious crawl ratio either (like jeepman784) but I did need the 2nd case to get the rigs to work w/35sand the 1.6 16v's 4cyl power .I dont really drive either of these on the road but have w/no issues
Old February 20th, 2009, 07:53 AM   #9
groundhog
groundhog's Avatar
JUNK!!!!
groundhog is offline   Reply With Quote
Old February 22nd, 2009, 01:32 PM   #10
A4X4SPIT
A4X4SPIT's Avatar
I was in front of you when I took your avatar picture
Old February 24th, 2009, 09:34 PM   #11
groundhog
groundhog's Avatar
HAHAHAHAH.......Thats cause I felt bad that you were not in a JEEP!!!
Old February 25th, 2009, 05:28 AM   #12
A4X4SPIT
A4X4SPIT's Avatar
I thought your rig was a chevy truck with a jeep body? chevy motor chevy axles Ill bet chevy trans too= JEEP
Old February 25th, 2009, 04:43 PM   #13
93trackaddict
93trackaddict's Avatar
93 tracker 8 valve
auto trans
31/10.5/15
5.12 diffs
stock transfer case
locked front and rear
I have to run low lock for best offroad performance
also have header and intake
It will run 65 on the highway comfortably
93trackaddict is offline   Reply With Quote
Old February 27th, 2009, 05:39 AM   #14
sami87
sami87's Avatar
87 Samurai 529 gears 4.28/1 t-case 34ltb,s 1.6 Sidekick 8valve 60 to 65 on the road
sami87 is offline   Reply With Quote
Page generated in 0.43699 seconds with 65 queries
