86 BII 4 wheel drive - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2009, 10:42 PM   #1
DeerHuntin9124
Blue on Black
DeerHuntin9124's Avatar
Default 86 BII 4 wheel drive
My bronco is still in progress but i think one of the previous owners swapped the electronic 4x4 for a manual t-case. Question is would the hubs have to be converted to lockouts for the 4 wheel drive to work right or would they work as is. First 4 wheel drive vehicle so im new to these sorta things. Suggestions appreciated. Thanks
DeerHuntin9124 is offline   Reply With Quote
Old February 13th, 2009, 10:58 PM   #2
88mudder
In the band!
i would highly recommend manual lockouts.
Old February 13th, 2009, 11:21 PM   #3
HVYRTFT
Reed my teef
HVYRTFT's Avatar
x2 on manual lockouts. And, it's a rather simple conversion process.
Unless you like buying auto hubs and not having 4x4 when you need it.
Old February 13th, 2009, 11:30 PM   #4
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Well, technically they'll work as is.
The hubs wouldn't have to be converted, but you may gain some benefits, like 4wd working when you actually need it. The automatic hubs are notorious for being festering piles of crap. You can try building up some spares from a junkyard, but I'd just assume that as soon as you run into issues, convert to manual hubs.
Hub Swap 1
Hub Swap 2
Basically find a similar body style BII or Ranger that has been put out to pasture (junkyard) that has manual hubs, and steal it all There is technically 2 different axles in these and they interchange. So to make sure no one swapped in the other axle, count the bolt holes on the front of the beam for the differential. Make sure it has the same amount as yours. Manual hubs are actually more common than the automatic ones for those years, at least in my experience.
And you should be set
Old February 14th, 2009, 08:07 PM   #5
DeerHuntin9124
Blue on Black
Hub Swap 1
Hub Swap 2
Hey thanks for the help. I went and "borrowed" the hubs from a rusting pile of BII but i was having jack problems and didnt get all the guts. Im going to buy a conversion kit just to make sure i have all new, well operating parts.
Old February 17th, 2009, 10:34 PM   #6
Jdc215
Jdc215's Avatar
i broke an axle shaft with those automatic hubs, long story but i have had no problems with the manual hubs
Jdc215 is offline   Reply With Quote
Old February 17th, 2009, 11:19 PM   #7
Captain Ledd
Ranger Addiction?
Well they will work, it's just they generally stop working. It seems to be a matter of when, not if.
Page generated in 0.28192 seconds with 44 queries
