I need a spool gun.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2009, 08:49 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default I need a spool gun..
ive got a Lincoln power mig 212.. awsome machine.. but i would like to be able to weld aluminum.. what spool gun do i need for my machine ?? i see nothing machine specific.. only looking to weld up to like 1/8" alum..
and then is it the same process as steel ??
Old February 14th, 2009, 05:49 AM   #2
Tizken
I have a miller spoolmatic 30a that I never use now. No idea if it could be made to work or not. I can get a picture of the connections on it if you want.
It was pretty simple to use once it was all set up, we used it for 1/4" diamond plate.
Tizken is offline   Reply With Quote
Old February 14th, 2009, 07:28 AM   #3
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
no alum is alot more touchy the cleaner the better and ive never had good luck with spool gun. they always seem to jam break wire ect
Old February 14th, 2009, 09:03 AM   #4
VonDirt
VonDirt's Avatar
youll need argon for sheilding rather than a Co2 mix.
aluminum is tricky as stated above. i use tig for that stuff, never used a spool so cant comment on that specifically.
let us know what you come up with.
VonDirt is offline   Reply With Quote
Old February 14th, 2009, 11:29 AM   #5
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
spool guns suck get a tig
Old February 15th, 2009, 06:31 PM   #6
CreativeFab
used to be Ironman
CreativeFab's Avatar
Here is what I use, it is the MagnumSG for the power mig 200. This model spool gun was replced by a newer one that should work with your 212. This one was $800 retail and the new are now half the cost. Contact MI Airgas and see what they have for your welder.
This spool gun works great from .125 all the way to .75 I run 030 for almost everything with this gun.
Old February 15th, 2009, 06:36 PM   #7
steveo
In the band!
I used to use a miller spoolgun to weld new liners in gravel trains. it worked ok, but that was thicker material. for 1/8" aluminum tig will be your friend.
Old February 15th, 2009, 07:15 PM   #8
kickstand
circling the drain
kickstand's Avatar
I used to use a miller spool gun to repair aluminum forms for pouring concrete walls, it worked fine. Tig is better, but how much welding do you plan to do?
Old February 17th, 2009, 12:50 AM   #9
Mclovin
"The Situation"
Mclovin's Avatar
after reading this and talking to a guy im working with who has done a shit load of welding.. ill prob jut have someone else weld these for me.. i have 2 peices of 1/8 alum. diamond plate i need butt welded..
Old February 17th, 2009, 12:51 AM   #10
Mclovin
"The Situation"
Mclovin's Avatar
do you have one ?? wana weld something ?
Old February 17th, 2009, 12:55 AM   #11
Nuggets
I fix stuff!
Nuggets's Avatar
I've had great luck with my spool gun but I weld mostly cast aluminum.
Old February 22nd, 2009, 11:36 AM   #12
kickstand
circling the drain
kickstand's Avatar
Yes, butt welded sheets I would tig
Page generated in 0.19769 seconds with 59 queries
