13.60 Trans Am. - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2009, 11:29 PM   #101
guest
Send a message via AIM to guest
Originally Posted by DannyDodge View Post
slow van truck
lol not interested. I think I know what your talking about. But can we get back on topic. About engine heads and vortecs.
guest is offline   Reply With Quote
Old February 12th, 2009, 11:29 PM   #102
///M_car_go
I woulda posted the one with the glow braclet lights, lol.
///M_car_go is offline   Reply With Quote
Old February 12th, 2009, 11:30 PM   #103
DannyDodge
oh wait, heres the view you'll be seeing
DannyDodge is offline   Reply With Quote
Old February 12th, 2009, 11:30 PM   #104
DannyDodge
fix'd
Old February 12th, 2009, 11:31 PM   #105
kevinr839
kevinr839's Avatar
The jr is what my 8 year old drives. the camaro is mine. It ran an 11.28 and only pulled the wheels a few inches for a split second. the front end may feel light going down the track but is not lifting.
kevinr839 is offline   Reply With Quote
Old February 12th, 2009, 11:31 PM   #106
///M_car_go
Ok, real talk now. Im gonna say yer car puts out 250 crank HP if yer lucky. To make the kinda power you wanna make you will have to spend some dollars on some decent stuff. You can run 11.5ish to 1 on 94 IF you had an aluminum head and someone that could time the car correctly.
Old February 12th, 2009, 11:32 PM   #107
DannyDodge
wheelies are wasted energy, but man are they bad ass
Old February 12th, 2009, 11:33 PM   #108
guest
Nice car. Seeing that I apologise for the comment earlier. AGAIN though. My car is twisting and lifting the wheel off the ground like one inch. If that.
Old February 12th, 2009, 11:33 PM   #109
xj-james
Original Gangster
xj-james's Avatar
K fukc you. Call me a idiot in front of me.
I call BS. I think you wouldnt even show up. You are a Pussy on and off the intra web. So why dont you just
SHUT YOUR WHORE MOUTH WHEN GROWN MEN ARE TALKING.
xj-james is offline   Reply With Quote
Old February 12th, 2009, 11:33 PM   #110
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
My 88' YJ with a mopar 360 is my toy.
making 310hp at the wheels is harder than making 310hp at the crank... you do have a loss of HP by the time it gets to the rear.
Old February 12th, 2009, 11:33 PM   #111
///M_car_go
Stoppies are bad ass.
Old February 12th, 2009, 11:34 PM   #112
Mclovin
"The Situation"
Mclovin's Avatar
They said I should be kinkin out ABOUT 330 horse at the fly wheel.
you really should watch those finger slips
you realize you're gonna loose a hell of a lot more than 20hp through your drive train right ? i believe it's about 20-30% with something older.. so you're looking at around 260-270 horse after drive train
so you've got a 3500 lb car running 260 horse to the ground.. you're looking around the HIGH 13's low 14's depending on how the cars suspension is working.. but still you're not near enough to pull the wheels..
and thats with 20% power loss
Old February 12th, 2009, 11:35 PM   #113
xj-james
Original Gangster
xj-james's Avatar
LIAR! You are so ignorant I feel my comp getting stupider after every post you make. Your car could not lift a butterfly 1 inch. Poser
Old February 12th, 2009, 11:35 PM   #114
guest
NICEE and yes I know this.
Old February 12th, 2009, 11:37 PM   #115
DannyDodge
ya mine does too with alot more done to it than your car
Old February 12th, 2009, 11:37 PM   #116
xj-james
Original Gangster
xj-james's Avatar
But you said it lifted the wheel you liar.
SHUT YOUR WHORE MOUTH WHEN MEN ARE TALKING
Old February 12th, 2009, 11:38 PM   #117
kevinr839
kevinr839's Avatar
As far as getting 12.1 by just milling your heads, it won't happen. You would need to add domed pistons. You could run pump gas with 12.1 but you would need to retard your timing to prevent spark knock. I would suggest buying a set of sportsman II's or soemthing. they flow better stock than most gm factory heads that have been worked on. And they are relatively cheap. Ypu can run vortec heads but you have to bu a different intake manifold due to the fact that the vortec heads only have 4 intake bolts per side opposed to the normal 6 per side. Put a 3.73 or 4.10 gear in the car and you will really see a differnce in power.
Old February 12th, 2009, 11:38 PM   #118
DannyDodge
you own a fucking chevy, call dart and buy some heads for pennys
Old February 12th, 2009, 11:38 PM   #119
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Instead of cumming on here claiming your car is going to make 410hp at the wheels with just head work, you need to dyno it, show the graphs.
You can't just come up with a HP number by the components in the engine...there is to many variables that come into play.
Old February 12th, 2009, 11:38 PM   #120
guest
WOW what the fukc . I SAID the car twist and the wheel comes of the ground. Its because the frames not tied. Go back and read my damn post about the wheel lifting. I was anwsering a question on the car twisting. GEEZE.
And xjjames. Please, please, please just shut your stupid ass mouth. You just looked like a stupid E-thug.
Tags
epic fail, waste of time, whore mouth.......shut it
Page generated in 0.77455 seconds with 84 queries
