13.60 Trans Am. - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2009, 09:20 PM   #41
Tweeternpi
Tweeternpi's Avatar
This is a funny Read. You do not know how to build or Tune and Engine. Save your money. Just have the heads redone and only Milled if they need to be. If you have them Milled you will never get the car to run right.
Tweeternpi is offline   Reply With Quote
Old February 12th, 2009, 09:24 PM   #42
AFRd_CJ5
AFRd_CJ5's Avatar
Originally Posted by a.j. hall View Post
I have some chevy truck heads. I cant remember the casting number though. The local machine shop said they were GM Torque heads. What about those?
By the time you spend money on any old GM castings to get them "workable", do any port/polish, valves/etc., just buy the best set you can afford for what you're doing.
Even some of the newer GM vortec heads are much better than any of the old castings you'll find and dump (waste, in my opinion) money into.
AFRd_CJ5 is offline   Reply With Quote
Old February 12th, 2009, 09:33 PM   #43
Toivo
Feel lucky?
Toivo's Avatar
you should probably buy a 426 Hemi, and put that into your transam, after you highlight your mullet and score a lifetime of Scorpions and Winger tapes.
Also required is a jean jacket and mirrored aviators.
Old February 12th, 2009, 09:45 PM   #44
guest
Send a message via AIM to guest
The casting for my other heads is 14102191. Are they good? And I was told vortec heads only fit fuel injection?
P.s. for the guy that asked. Im running a Muncie Rock Crusher 4 speed trans with the stock rear end rebuilt with posi. I am going to instal frame ties and soon as I get the cash. I just want to get it running for now.
guest is offline   Reply With Quote
Old February 12th, 2009, 09:52 PM   #45
AFRd_CJ5
AFRd_CJ5's Avatar
Like I said, I wouldn't use any stock casting unless it was a vortec style head. You can absolutely run vortec heads with a carb/standard intake. A lot of people do so. In fact, one of the guys in our group runs a vortec headed 383.
Old February 12th, 2009, 09:59 PM   #46
guest
Ok sweet!!
The bigger CC the better in a head right?
Also, I assume I run vortecs with my edelbrock RPM performer right?
Old February 12th, 2009, 09:59 PM   #47
Fraser
Fraser's Avatar
Honestly, dump those heads. I would not waste any money on those castings. By the time you spend money doing work to those, you can get a much better new assembled casting for probably the same price.
hmmm, sounds like all ive heard about all old chevy heads= junk
Old February 12th, 2009, 10:00 PM   #48
guest
Also by vortec heads, do you mean heads off of any vortec engine?
Old February 12th, 2009, 10:01 PM   #49
Toivo
Feel lucky?
Toivo's Avatar
Im running a Muncie Rock Crusher 4 speed trans .
I call bullshit. A LOT of bullshit.
Old February 12th, 2009, 10:05 PM   #50
guest
Thats what it is. Or at least thats what we were told. It looks nothing like a T-10 which came in these cars. My car has always been a four speed from the factory. They only made roughly 1200 cars exactly like mine.
Old February 12th, 2009, 10:16 PM   #51
Fraser
Fraser's Avatar
sound of a genius right here you come up w/ a pic somebody might believe you
Old February 12th, 2009, 10:18 PM   #52
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
I got an idea... fuck off.Go stuff your boy friends cock in your mouth. My mom works all the time to take car of my little sisters. My parents are divorced. Mom pays house paymnet and everything by her self. So fukc you.
Ahh, so you rip on peoples wifes but when someone talks about your mom you go balistic. . . interesting
O and your TA is a fat pig and will run maybe 15s
Old February 12th, 2009, 10:20 PM   #53
Tweeternpi
Tweeternpi's Avatar
So how bad is the car twisted? I have a friend with an 89 with a 355 in it. You can see where the car twist from the power. He had Subframe connectors on his car. Anyone who is thinking of building fbodys would put those in. If your car had all the things done to it has they told you, That car would have Cracks all over it.
Old February 12th, 2009, 10:21 PM   #54
Chiefwoohaw
So what rear end is it? 10bolt? 12 bolt? Will it handle your 200 wheel horsepower?
Old February 12th, 2009, 10:28 PM   #55
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
the smaller the CC the more compression you'll get.
The stock rear end is a 10bolt? If so say bye bye!!
And I'll laugh when you blow your shit if you spray Nitrous. You can't just slap heads on and call it good... for one you'll need the correct type of pistons that will be able to handle the Nitrous. If your tuning the carb. you'll probably blow yourself up as you'll hit it while its lean.
for someone with no experience with what they are doing, your best to buy a car thats already built with what you want, or to buy an engine already built.
Plato2k5 is online now   Reply With Quote
Old February 12th, 2009, 10:34 PM   #56
Mclovin
"The Situation"
Mclovin's Avatar
id spend some time on motownmuscle.com they will have oodles more info than most people here.. just dont make the same mistake i did with my 1st engine build. and thats going into the summit cat. and buying all the parts that are listed for your make and model engine.. mine worked out good but if i had done the research and bought parts that were meant for each other it wouldve been a shit ton better !
Old February 12th, 2009, 10:37 PM   #57
guest
The car is not twisted at all and all the body lines and gaps are perfect. It does twist a bit. About half way down the track the front passenger tire lifts off the ground and stays until you let off.
10 bolt with new gears already. Car only has 100,000 on it. And im probably pushin more like 310 to the wheels.
The car has the Ws6 Suspension which isnt as hard on the body and drivetrain when you pull holeshots and such. I know how to drive the car and how to pull holeshots. Kinda have to ease of the clutch slowly to keep the pressure on the gears and such and then let it go and hold the trottle down. Also, the NOS was a joke. Even though I would be fine with a 100 shot. I believe teh pistons are forged along witht he rods. I wouldnt chance it though.
Old February 12th, 2009, 10:38 PM   #58
guest
Hey ball sack. My car ran 13.50s on street tires back in 1999.
Old February 12th, 2009, 10:40 PM   #59
guest
Thanks ill check it out.
Old February 12th, 2009, 10:41 PM   #60
Tweeternpi
Tweeternpi's Avatar
Do you know what WS6 is???
Tags
epic fail, waste of time, whore mouth.......shut it
Page generated in 0.63939 seconds with 84 queries
