13.60 Trans Am. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2009, 07:31 PM   #21
guest
Send a message via AIM to guest
Some one seriously school me on this!I was obviously told wrong on how this whole thing works. What should I get the heads milled to? As of right now the car ran better on mid grade than it did on regular.
guest is offline   Reply With Quote
Old February 12th, 2009, 07:45 PM   #22
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
bigjay is offline   Reply With Quote
Old February 12th, 2009, 07:48 PM   #23
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by Rocky View Post
In reality if the has AL heads you can get by with 93 oct.
I respectfully disagree - he does not have the engine management to cope with 12:1 on pump gas.
@clarkstoncracker
Old February 12th, 2009, 07:50 PM   #24
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
If you're taking it to a reputable builder, tell him to make it run on midgrade - premium if you can afford it. He will know what to do with machining, but you really can't just go by "milling the heads" - your piston shape, deck height and combustion chamber will all need to work together to run well.
Talk to your builder and listen to him.
@clarkstoncracker
Old February 12th, 2009, 07:54 PM   #25
guest
Alright thanks. How much Hp difference would setting it for mid grade make than setting in for 93 make?
Old February 12th, 2009, 07:55 PM   #26
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
AJ if i was you i woud run 10% or 20% nothing over that or you'll blow a rod or something....
Rockstar is offline   Reply With Quote
Old February 12th, 2009, 08:05 PM   #27
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
It will probably be a wash: higher compression ratio improves combustion efficiency, however, you will probably have to run less spark. Spark timing, depending where you are on the MBT curve, is more potent than compression ratio.
I would rather have an engine I could run midgrade in and run a bit more advance than a high compression motor that I had to pull spark out of to run without detonating. Besides, you're young and don't have tons of money - you'll cheap on fuel when you're broke and running regular unleaded in a mild engine is better than on something with so much compression.
@clarkstoncracker
Old February 12th, 2009, 08:26 PM   #28
AFRd_CJ5
AFRd_CJ5's Avatar
And I'd have to disagree with that. It can be done with aluminum heads, and probably even with iron. Your cam profile plays a large factor with what you can get away with.
AFRd_CJ5 is offline   Reply With Quote
Old February 12th, 2009, 08:36 PM   #29
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
AJ, you need to do SOME research before pulling a number out of your ass and expecting to get that type of power from just shaving the heads.
To make that kind of power you need a combination of parts as stated above. Pistons are needed to net the type of compression you want in combination with shaving the heads....also different thickness head gaskets. You'd have to have work done to the heads so they flow better (port and polish), bigger valves, etc... and also the type of cam.
Just for reference, my mopar 360 has flat top pistons, I'm somewhere around 10:1 compression, heads are port and polished, and i have a mild cam.... I'm NOWHERE near 450hp. I'd be lucky to have 300hp at the crank.
Also what engine is this? Please tell me its not the 305.....
Oh and if you shave the heads to much, you'll have to get your intake shaved down as well, otherwise it will not fit.
Old February 12th, 2009, 08:42 PM   #30
Nuggets
I fix stuff!
Nuggets's Avatar
Run 23:1 compression. There is a fuel out there that is so good it is more expensive than premium gasoline and it loves this compression ratio. This fuel is so good some faggety actor named Vin uses it for his last name.
Old February 12th, 2009, 09:05 PM   #31
ajmorell
ajmorell's Avatar
bwahahahaha
Old February 12th, 2009, 09:11 PM   #32
guest
SO just tell the builder I want to run on Midgrade. What compression should I shoot for?
No its a 1970 LT1 4 bolt 350 bored to 355 out of a 70's vette with:
TRW 174 Comp Cam .468 Lift.
Flat top pistons with ears cut for valve clearance.
Edelbrock RPM performer Intake
Edelbrock 650 carb.
MSD Coil
MSD Box
Heads are cast # 462624 (http://www.mortec.com/castnum.htm)
Not sure on wether or not there ported or polished. It does look like someone tried to open up the exhaust ports with a dremel or something. But I don't know.
Thats all I know of that it has.
Old February 12th, 2009, 09:14 PM   #33
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
There are a lot of things you need to do to gain that type of power. It is not cheap!
Old February 12th, 2009, 09:25 PM   #34
AFRd_CJ5
AFRd_CJ5's Avatar
Honestly, dump those heads. I would not waste any money on those castings. By the time you spend money doing work to those, you can get a much better new assembled casting for probably the same price.
Old February 12th, 2009, 09:31 PM   #35
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
I got an idea get mommy 2 buy u a new motor. Seems like u get all your shit handed 2 u.
mpsbvp is offline   Reply With Quote
Old February 12th, 2009, 10:06 PM   #36
guest
I got an idea... fuck off.Go stuff your boy friends cock in your mouth. My mom works all the time to take car of my little sisters. My parents are divorced. Mom pays house paymnet and everything by her self. So fukc you.
Old February 12th, 2009, 10:09 PM   #37
guest
I have some chevy truck heads. I cant remember the casting number though. The local machine shop said they were GM Torque heads. What about those?
Old February 12th, 2009, 10:09 PM   #38
guest
Nos lol
Old February 12th, 2009, 10:11 PM   #39
oz97tj
Wasn't this attached?
oz97tj's Avatar
I just don't get why people ride you so much. You seem like such a nice kid.
********GLFWDA.org********
Old February 12th, 2009, 10:16 PM   #40
dodgeboy
redneck truck club
dodgeboy's Avatar
all that power and what kind of trans are you going to run??? what rear end??? gear??? stall?? how are you going to get it to hook up??? them cars like to twist!
dodgeboy is offline   Reply With Quote
Tags
epic fail, waste of time, whore mouth.......shut it
Page generated in 0.36887 seconds with 84 queries
