F250 Door Light Switch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2009, 09:47 AM   #1
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Default F250 Door Light Switch
Has anyone needed to replace one of these yet? It's really tiny and it's not located in the door jamb. I'm assuming that it's built into the latch assy, but can someone please confirm this before I start tearing into it?
2002 Superduty.
Thanks!
Old February 12th, 2009, 03:03 PM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
OK- Handled! Thank you "the Deisel Stop.com"
WD 40 works wonders!!!!
Old February 12th, 2009, 04:18 PM   #3
Yota Bill
yea, these just get packed with grease and dirt from the latch, and they stick in, which is the position they are in when the door is open, so the dome light stays on, etc...
clean em right through the latch without taking anything apart, works at least 95% of the time....but if you do need to change one, its pretty easy, remove the door panel, unplug the switch, and then turn it 1/4 turn (as oposed to 2/8 turn, or 3/12 turn) and it comes right out...
Old February 14th, 2009, 09:15 AM   #4
bigcountrysg
Countryboy
bigcountrysg's Avatar
Use brake cleaner then use a dry lubricant. That way you don't collect dirt on the latch.
I do this with my F-250, it is funny how just a little dirt makes that switch not work.
bigcountrysg is offline   Reply With Quote
Old February 14th, 2009, 10:14 AM   #5
Bones
Bones's Avatar
mine are Fed up too... do I just spray it straight into the door latch, or do I have to aim up or down or?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 14th, 2009, 10:46 AM   #6
Yota Bill
mostly up, gravity will take it down
Page generated in 0.20295 seconds with 41 queries
