89 AOD noises - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2009, 10:42 PM   #1
busyfixin
Balls Deep
busyfixin's Avatar
Default 89 AOD noises
a good freind has an 89 f-150 302/aod/1356. ive had it sitting out back for a few years, so when he needed a ride recently, we pulled it in the shop and fixed the few things that we knew were wrong with it. he has been driving it for a week or two now, and when you let off the throttle to slow down for a corner or stop sign, the trans will start clicking away, like a ratchet almost. it sounds like something is free-wheeling in the trans. it is deffinitely not good sounding, but i dont know much about these transmissions. the sound will go away if the throttle is applied enough to catch the trans up the the traveling speed, but continue decelerating.
what may be making the noise, and is it fixable? should he just run it till it quits?
Old February 11th, 2009, 10:44 PM   #2
88mudder
In the band!
My AOD does the same thing, its a quiet click noise. The trans has always worked fine no problems. Mine is out of an 89 Bronco.
Old February 11th, 2009, 10:47 PM   #3
busyfixin
Balls Deep
busyfixin's Avatar
yea, it sounds similar to the speedo gear slipping or stripping, except it is getting louder every day.
Old February 13th, 2009, 09:32 AM   #4
Hoofinit
Hoofinit's Avatar
Yahoo has a pretty active group on aod's, some of those guys are quite knowlegdeable.
Tim
Hoofinit is offline   Reply With Quote
Page generated in 0.24340 seconds with 35 queries
