*SOLD* Bosch Hydro-Max Hydroboost, new for Medium Duty & Unimog - Roch Hills - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2009, 09:08 PM   #1
amundaza
Terminator 2
amundaza's Avatar
Default *SOLD* Bosch Hydro-Max Hydroboost, new for Medium Duty & Unimog - Roch Hills
Hey guys & gals,
This is a new Bosch Hydro-Max hydroboost system. It is brand new, never installed.
These are used on Ford F53 (motorhome / coachbuilder chassis) and GM 4500/5500/6500, etc... They're also used on Kennworth medium-duty trucks.
This is good for up to 22k GVWR. It has a 2" bore master cylinder.
It is NOT RECOMMENDED for our typical 4x4 Hydroboost applications, but rather something BIG with big axles and BIG brakes, like a medium duty truck or Unimog axles.
DON'T BUY THIS if you just want HB for your light duty 4x4 ... go buy an Astro HB unit ... that's what those are designed for.
IF you have something bigger, like a Kaiser 6x6 or Med. duty truck with BIG axles and brakes, or Unimog axles, then this may be WHAT YOU WANT to stop the big tanks!
$500 or trade.
Sincerely,
GregTaylor
Rochester Hills, MI
1989 Grand Wagoneer "Terminator 2": Water/Hydrogen Injection Coming Soon ... 330" AMC stroker V8. 5" lift 31" BFG A/T's. Killer32 front bumper & DozerII rear swing-out bumper ... Oh Yeah! And a FISH Carburetor!
Last edited by amundaza; February 16th, 2009 at 04:30 PM. Reason: adding in Unimog application
amundaza is offline
Old February 10th, 2009, 09:11 PM   #2
amundaza
Terminator 2
amundaza's Avatar
It has been noted by Elliot Sydnam, the HB expert over at IFSJA.org, that this setup could possibly be used with Unimog axles. Here is his comment.
"You might check out who is running MOG axles over at Pirate and see if they are interested in it.
Elliott"
Sincerely,
GregTaylor
Rochester Hills, MI
amundaza is offline
Old February 11th, 2009, 05:49 PM   #3
amundaza
Terminator 2
amundaza's Avatar
bump!
amundaza is offline
Old February 12th, 2009, 05:49 AM   #4
amundaza
Terminator 2
amundaza's Avatar
bump
amundaza is offline
Old February 12th, 2009, 07:40 PM   #5
amundaza
Terminator 2
amundaza's Avatar
Trades considered ....
1) 23 spline input Atlas II transfer case
2) Jeep NV3550 or NV4500 tranny setup (for AMC V8 or 4.0L)
3) Jeep 700R4 setup
4) What else you got for an AMC V8 or Grand Wagoneer?
Thanks.
GregTaylor
Rochester Hills, MI - 1989 Grand Wagoneer "Terminator 2"
amundaza is offline
Old February 13th, 2009, 08:04 AM   #6
amundaza
Terminator 2
amundaza's Avatar
Other trades considered ....
1) Rear disc brake kit for the Jeep GW Dana 44
2) AX-15 Jeep tranny setup (from 4.0L)
3) Matching front/rear GW axles with lockers and 3.31-4.56 gears (DSD front and centered rear) or similar axles set up for a Full Size Jeep.
4) GW Aluminum radiator
Thanks,
Greg :)
amundaza is offline
Old February 14th, 2009, 08:01 PM   #7
amundaza
Terminator 2
amundaza's Avatar
bump
amundaza is offline
Old February 15th, 2009, 07:49 PM   #8
amundaza
Terminator 2
amundaza's Avatar
Bump
amundaza is offline
Old February 16th, 2009, 01:14 PM   #9
amundaza
Terminator 2
amundaza's Avatar
Sale pending ....
Greg Taylor
amundaza is offline
Page generated in 0.28802 seconds with 50 queries
