Ford 2wd 4r100(E4OD), bolts up to 5.4 -FOUND- - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2009, 08:54 PM   #1
Daddy Dan
SBF Nut
Daddy Dan's Avatar
Default Ford 2wd 4r100(E4OD), bolts up to 5.4 -FOUND-
Looking for a good Ford 4R100 tranny 2wd for our '98 E-250 w/ 5.4.
Last edited by Daddy Dan; April 30th, 2010 at 01:19 PM. Reason: corrected tranny model
Daddy Dan is offline
Old February 18th, 2009, 04:22 PM   #2
Daddy Dan
SBF Nut
Daddy Dan's Avatar
still looking
Old February 25th, 2009, 08:08 PM   #3
Daddy Dan
SBF Nut
Daddy Dan's Avatar
still need this
Old February 26th, 2009, 09:08 PM   #4
Strangler
Strangler's Avatar
If 4.6 and 5.4 have the same bolt pattern, I have one. 42k, perfect working order out od an 04 F-150. $500 with converter
Strangler is offline
Old February 26th, 2009, 09:24 PM   #5
blownexploder94
Todd
blownexploder94's Avatar
they do have the same bolt pattern but i believe they are a different trans, i think the 04 f150 has a 4r70w or 4r75w
blownexploder94 is offline
Old February 27th, 2009, 08:27 AM   #6
Strangler
Strangler's Avatar
Ok. sorry then.
Old March 2nd, 2009, 09:10 AM   #7
Daddy Dan
SBF Nut
Daddy Dan's Avatar
If your unsure what tranny model you have, the 4R100(E4OD) has a 20 bolt pan while the 4R70W(AODE) has a 14 bolt. I need the 20 bolt pan model. Need a good working transmission.
Old March 2nd, 2009, 09:13 AM   #8
Strangler
Strangler's Avatar
Mine has 14, sorry.
Page generated in 0.15387 seconds with 47 queries
