3-link front end ?'s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2009, 09:23 AM   #1
Grassman
2jz specialist
Grassman's Avatar
Default 3-link front end ?'s
i am tearing out my current front end and looking to fab up a 3 link with a trac bar. i dont thinkk it has any bearing, but im running coilovers
questions:
1) similar to a 4 link, does the upper link need to be about 70% of the lower length?
2) does the upper need to be "triangulated" somewhat, or paralell to the jeep?
3) my trac bar needs to approx anme length and angle as the draglink with jeep sitting on the level, right?
any help is appreciated, thanks guys!
Old February 10th, 2009, 09:26 AM   #2
Grassman
2jz specialist
Grassman's Avatar
mod, you can move this to fab section if more appropriate.
Old February 10th, 2009, 09:26 AM   #3
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
front link can be parallel no need for triangulation
trac bar should as long as you can get it and parallel with the drag link. YES
Old February 10th, 2009, 09:36 AM   #4
Grassman
2jz specialist
Grassman's Avatar
so longer than the draglink is the way to go?
Old February 10th, 2009, 09:37 AM   #5
hosejockey4506
Visiting Admin
same length i thought from what i remember hell i dont know ask hagger or 95 geo they are more into the 3 link stuff
Old February 10th, 2009, 10:06 AM   #6
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Flatter/longer is better, but try and match your drag link length and angle. Packaging stuff is the hardest part, so do what you can. Everything is a compromise.
JcrOffroad
Zoom Zoom!
Old February 10th, 2009, 10:08 AM   #7
1badzuk
1badzuk's Avatar
do you even need a track bar if the upper link is a wishbone with poly bushings on the end?
1badzuk is offline   Reply With Quote
Old February 10th, 2009, 10:15 AM   #8
Check out this thread, there is some good info here:
http://www.greatlakes4x4.com/showthread.php?t=116419
Old February 10th, 2009, 10:15 AM   #9
Wouldn't think so. Naturally, you'd want a full hydro setup not to have bumpsteer....
Old February 10th, 2009, 10:17 AM   #10
hosejockey4506
Visiting Admin
thats basically a 4 link.
Old February 10th, 2009, 10:49 AM   #11
Grassman
2jz specialist
Grassman's Avatar
that it what i have now, it sucks, the bump steer is so bad im just gonna start over.
yup
Old February 10th, 2009, 11:11 AM   #12
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
you could minimize it if you were able to get a long, flat drag link. it'd be no different than a stock leaf spring front end in terms of bump steer.
Old February 10th, 2009, 11:25 AM   #13
jeepnxj96
jeepnxj96's Avatar
go radius arms (y links), they are easy to setup articulate quite well, then just run an adjustable trackbar, can't get any easier than that.( this is how mine is setup and I have been running like that for ~4 years now)
Old February 10th, 2009, 11:40 AM   #14
95geo
newbie
95geo's Avatar
that is the worst advice you could give.... a 3 link will out perform a radius arm setup 10 fold and all that is invilved is ONE frame side mount.
Old February 10th, 2009, 12:53 PM   #15
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
ditto
Old February 10th, 2009, 01:12 PM   #16
True. Also the reason vehicles like the YJ started going with a track bar with leafs.
Old February 10th, 2009, 01:34 PM   #17
hosejockey4506
Visiting Admin
ditto
x4/4
Old February 10th, 2009, 02:39 PM   #18
Grassman
2jz specialist
Grassman's Avatar
questions:
answers:
1)still waiting, i assume seperation of upper and lower links similar to 4 link need to be .25 x tire diameter, and try to stay close to 70% of lower link length.
2) link can be paralell to jeep, to reduce binding between trac bar and upper link
3) trac bar similar angle and length to draglink
Old February 10th, 2009, 02:45 PM   #19
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
questions:
answers:
sort of, the length of the upper arm will depend on what kind of pinion angle change you are looking for as the suspension travels. the three link will act similiar to how a 4 link does.
I like this youtube demonstration :
link
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
do a search on youtube for "4 link" or "4 link supsension" and you should find some pretty helpful stuff.
Old February 10th, 2009, 03:26 PM   #20
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
the lastest version of the 4-link calc does pinion angle change over travel
http://www.pirate4x4.com/forum/showthread.php?t=204893
what I did was to put in the numbers from my 3-link into this to be able to check how much pinion angle there would be from the side view. I just copied the single upper link measurements into both fields. The AS&#37; value and pinion info carries over between 3 and 4-link, but the roll center and roll axis do not.
Page generated in 0.70278 seconds with 83 queries
