A little stuck on a T-18 ID *updated: solved - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2009, 03:07 PM   #1
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Default A little stuck on a T-18 ID *updated: solved
So I finally bothered to pull my transmission and at least look at it, preferably rebuild it, the kits were only ~$200 so I figured what the hell...
Novak offers 2 kits that I have narrowed down to as being my transmission:
1979-1982 master rebuild kit
1983-1991+ master rebuild kit
This is where I'm stuck, as I can't find anything definitive as to which of those years I have. This is what I've found:
13-01-065-807 < Case# It is indeed a '79+ T18
13-01-097-809 < Cover No other information present
Reverse is Over and down (also pointing to '79+)
Cast Aluminum shift forks - Yet again, '79+
I was told it came out of an '86 F250, I did not see the vehicle or removal
Cast Iron bearing retainer - way too heavy to be aluminum, and wrong color
*edit: Just thought to check with a magnet to be extra certain, it is indeed cast iron
The later ones ('83-91) shouldn't have the cast iron retainer, but an aluminum one, though supposedly they can be interchanged. Since I never saw what it came out of, there's no telling what it's actually from, but supposedly it's the later unit ('86) from what I was told.
is there any way to tell for sure, I don't want to get 1/2 way through my rebuild and find that I have a few parts different/missing.
Last edited by Captain Ledd; February 8th, 2009 at 03:22 PM. Reason: A bit better grammar and the magnet check.
Old February 9th, 2009, 05:36 PM   #2
Captain Ledd
Ranger Addiction?
Update:
Ended up giving Novak a call and after about 15 minutes it was concluded that the only difference between the kits was in fact the front input retainer and some of it's specific components. And everything else should be the same between the two.
Kit, T18 master rebuild, Ford & Jeep, 1979-1982
Part: #T18MR-3F
Kit, T18 master rebuild, 1983-1991+ Ford
Part: #T18MR-4F
Page generated in 0.18876 seconds with 29 queries
