1999 windstar (fixxed) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2009, 11:50 AM   #1
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
Default 1999 windstar (fixxed)
ignition control mod went out, i replaced it, now it wont start, turn the key to start and the anti-theft light blinks fast and thats it, all the electrical system turns on with the key, i do not have the key with the mod in it, my 1999 is an early model so it was not equipted with it
help before i say and put 2.5 tons under it
spr_chicken is offline   Reply With Quote
Old February 7th, 2009, 06:10 PM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
so it won't even turn over?
maybe a little more info
Old February 8th, 2009, 02:09 AM   #3
spr_chicken
had a friend come over with a snapon scanner its the PATS system i have to take it to the dealer and have the clear it his scanner doesnt have the add on for the anti theft system
Old February 8th, 2009, 09:21 AM   #4
fsumotorhead
N8KVB
how can it be the Pats system if your key doesn't have a chip in it?
Old February 8th, 2009, 09:37 AM   #5
shredder70
Chillin with the top off.
shredder70's Avatar
For shits and grins. Disconnect the battery, Then reconnect it. Put the key in the door and lock then unlock it then try to start it again.
shredder70 is offline   Reply With Quote
Old February 8th, 2009, 01:16 PM   #6
spr_chicken
tried that
Old February 8th, 2009, 05:54 PM   #7
shredder70
shredder70's Avatar
Originally Posted by spr_chicken View Post
tried that
we had a expidition do the same thing. If you take the steering wheel and tilt it all the way down and then hit the steering wheel while trying to start it. Sounds weird buit it worked.
Old February 9th, 2009, 07:14 AM   #8
frdboy
frdboy's Avatar
What module did you replace, the pcm?
Did you put a new or used one in?
Old February 16th, 2009, 02:01 PM   #9
spr_chicken
i replace the ignition mod and the instrument cluster
its fixxed now the wire on the bottom of the key switch was loose
(the wire came out of the connecter)
so after that got fixxed the shop was able to reset the computer
Page generated in 0.24118 seconds with 50 queries
