Suggestions On Tie Rod Fab - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 5th, 2009, 06:59 PM   #1
dingle dave
PARTS SLINGER
dingle dave's Avatar
Default Suggestions On Tie Rod Fab
I'M WONDERING WHAT PEOPLE THINK OF WELD IN BUNGS VERSUS THREADING THE ROD ITSELF. I'M BUILDING MY OWN TIE ROD AND THE TAPS TO THREAD ARE PRICEY SO I'VE LEANED TOWARDS THE WELD IN THREAD BUNGS BUT WONDER HOW DURABLE THEY ARE. PLAN ON TRAIL DRIVING SO I DON'T NEED IT LETTING LOOSE AT SPEED.
dingle dave is offline   Reply With Quote
Old February 5th, 2009, 11:44 PM   #2
sodapop
Support the Sport!
sodapop's Avatar
I've had a weld in bung fail at the weld. I do think that this is related to flat towing though. If I had to do it all over again, i think I'd go with threading the rod however I think weld in bungs are a good choice too. When i reweld this bung in, I am going to add 2 thin straps 180* apart from each other on the joint to increase strength. I still think they are a very viable solution.
Old February 6th, 2009, 06:46 AM   #3
groundhog
groundhog's Avatar
It should be just fine ,it is done all the time.
groundhog is offline   Reply With Quote
Old February 6th, 2009, 06:52 AM   #4
Bishop
Bishop's Avatar
i don't have any experience with them but i would think if they are welded properly they shouldn't fail.
Old February 6th, 2009, 07:02 AM   #5
dingle dave
PARTS SLINGER
With My Luck I Wouldn't Get A Second Chance. I'm Not Ready To Die.MAYBE I BETTER JUST PAY SOMONE TO THREAD THE ROD FOR ME
Old February 6th, 2009, 07:34 AM   #6
Bishop
Bishop's Avatar
JCR sells it by the inch...
http://www.jcroffroad.com/Merchant2/...tegory_Code=S6
it costs more but that includes it already taped.
Old February 6th, 2009, 08:28 AM   #7
95geo
newbie
95geo's Avatar
I like tapping the material directly. If you want to do inserts I can TIG them in for you so you'll have a better joint than a MIG bead.
I have a few common taps too if you would rather do that.
I'm not too far from you, let me know if you are interested.
Old February 6th, 2009, 02:05 PM   #8
CreativeFab
used to be Ironman
CreativeFab's Avatar
Try a rosette weld 180 degrees on each insert, drill a hole in other words, into the tube and fill with weld penetrating into the insert.
Old February 6th, 2009, 03:55 PM   #9
sodapop
Support the Sport!
sodapop's Avatar
I was kicking that Idea around too. honestly, I was VERY surprised that this one failed. I'm chalking it up to poor prep on my part.
Old February 7th, 2009, 07:20 AM   #10
dingle dave
PARTS SLINGER
have to check them out
i thought about plug welding the inserts as well.
Old February 7th, 2009, 08:39 PM   #11
Bishop
Bishop's Avatar
never thought about that, awesome idea.
Old February 8th, 2009, 06:59 AM   #12
dingle dave
PARTS SLINGER
DO YOU HAVE THE 7/8-18 LEFT HAND TAP?????????
Old February 8th, 2009, 11:27 AM   #13
95geo
newbie
95geo's Avatar
Yes
Old February 8th, 2009, 11:32 AM   #14
Mclovin
"The Situation"
Mclovin's Avatar
i used 1.5" .250 wall and a set of 3/4 heims from ruffstuff.. welded the inserts in and we'll see it works.. if you want added insurance.. id go ahead and plug weld the inserts too.
Old February 8th, 2009, 11:36 AM   #15
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
That is how I did my links way back when (2001) and will do the same on my new links here shortly. Rosette weld at the bottom of the weld in bung to keep from damaging threads. Also V notch where the tube adapter meets the tube. That way you get a good weld joint to work with.
Old February 8th, 2009, 07:13 PM   #16
dingle dave
PARTS SLINGER
Yes
if you want to make it. pm me. i'll pay you. let me no. might as well help the local guy out, plus i'll save on shipping costs.
Old February 13th, 2009, 03:11 PM   #17
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I did the same thing to my trac bar. V notched the end, drill a 1/2" hole for a rosette and TIGed it in. 12,000 miles and no problems.
Old June 20th, 2009, 05:16 PM   #18
dirtrider
Dopey
dirtrider's Avatar
I made mine out of 1.5" , .25" wall dom and welded the bungs in w/ a 110 mig. I had my ball joints fail at TRRC and the knuckle came off and it ruined the the heim. the bung is still fine....
http://www.greatlakes4x4.com/showthr...=136235&page=2
dirtrider is offline   Reply With Quote
Old June 21st, 2009, 03:02 PM   #19
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Mine are welded bungs into a 1.75" .375 wall DOM tie rod and take direct repeated abuse being that my TR is in the stock (not high steer) location to protect my ram, and thus is used for battering. No issues for me.
Nuzzy is offline   Reply With Quote
Page generated in 0.47751 seconds with 80 queries
