Welding Rearend - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2009, 11:42 PM   #1
Jb1986
Bowtie boy
Jb1986's Avatar
Default Welding Rearend
Has anyone welded a Tracker rearend? If so wut is the best way to get into the spider -gears to weld them solid..Also if I cant figure out how to get in there anyone have a mini spool for one Let me know wut u know...
Jb1986 is offline   Reply With Quote
Old February 5th, 2009, 06:35 PM   #2
scottie
Eye candy
scottie's Avatar
you get into them the same way you get into many spider gears???
You remove center section, do what you have to do to weld it, then put it back together...
Old February 5th, 2009, 08:45 PM   #3
cruiserjg
dodge man
cruiserjg's Avatar
Pack it with JB weld.
cruiserjg is offline   Reply With Quote
Old February 5th, 2009, 08:46 PM   #4
steveo
In the band!
drain the fluid, they will weld.
Old February 5th, 2009, 08:49 PM   #5
88mudder
In the band!
Braze it
Old February 5th, 2009, 09:27 PM   #6
scottie
Eye candy
scottie's Avatar
http://www.izook.com/tech/samurai/dr...ozzy/fozzy.htm
Old February 5th, 2009, 09:30 PM   #7
88 TONKA TOY
Rockin an XJ
88 TONKA TOY's Avatar
Send a message via MSN to 88 TONKA TOY
FTW
88 TONKA TOY is offline   Reply With Quote
Old February 11th, 2009, 08:21 AM   #8
groundhog
groundhog's Avatar
Just for shits I wonder how long this would last if you just packed allspider gears with JB, I say 5 or 6 min's!!!! It would be funny to do.
groundhog is offline   Reply With Quote
Old February 11th, 2009, 09:47 AM   #9
crazymays77
i welded mine and havent had any problems with it. they are a little diff then standard rearends but not hard to do. depending on where you are i might be able to do it for you.
crazymays77 is offline   Reply With Quote
Page generated in 0.23984 seconds with 50 queries
